Ilogic check if layer is empty
Well my question is quite simple. Is there a way with iLogic to see if a layer is empty?
I could check all the curves in all views in an .IDW and see if any curve is on the pointed layer...But just checking if its empty would be better and faster.
Sorry if it's been asked before... I made a quick search and couldn't find it.
Thks in advance
bradeneuropeArthur
What do you mean with empty?
Do you actually not used in the drawing?
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
