iLogic check for and delete all unresolved components
Hi Guys,
I'm looking for some solution which allows me to check for all unresolved components within the assembly and delete them if there are any.
Is it possible to create the iLogic rule to do that?
Thanks in advance for help.
Best Regards
Tomek
Replies (9)
AlexFielder
From this page: http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-0123304B-EC33-4430-B4F1-CBF225CB5B8F
comes this example iLogic Rule (Adapted slightly, because at the page above the code was VBA):
Public Sub Main()
  Dim oFile As File = ThisApplication.ActiveDocument.File
  Call ProcessReferences(oFile)
End Sub
Private Sub ProcessReferences ( ByVal oFile As File )
  Dim oFileDescriptor As FileDescriptor
  For Each oFileDescriptor In oFile.ReferencedFileDescriptors
    Debug.Print oFileDescriptor.FullFileName
    If Not oFileDescriptor.ReferenceMissing Then
      ' Since the ReferenceMissing has returned False, the ReferencedFile will return a File
      ' Recurse unless this is a foreign file reference
      If Not oFileDescriptor.ReferencedFileType = kForeignFileType Then
        Call ProcessReferences(oFileDescriptor.ReferencedFile)
      End If
    End If
  Next
End Sub
In theory you could use the same approach with a simple modification, instead of just checking whether the "oFileDescriptor.ReferenceMissing", you could do this:
If oFileDescriptor.ReferencedDocument = nothing then
'delete oFileDescriptor
End If
Of course, I have to ask why you want to delete unresolved references at all? Since in doing so, it will likely mean you'll end up with broken Assemblies and referencing drawings. Is it a dataset you inherited/don't have the time/money to fix?
frederic.vandenplas
Hi, this is created in vba, switch the commented line to actually delete the occurence
Sub DeleteUnresolvedFiles()
        Dim oFile As Inventor.File
        Set oFile = ThisApplication.ActiveDocument.File
        Dim oDoc As AssemblyDocument
        Set oDoc = ThisApplication.ActiveDocument
        oDoc.Save
        Dim oDocDef As AssemblyComponentDefinition
        Set oDocDef = oDoc.ComponentDefinition
        Call ProcessReferences(oFile, oDoc, oDocDef)
End Sub
Private Sub ProcessReferences(ByVal oFile As Inventor.File, oDoc As AssemblyDocument, oDocDef As ComponentDefinition)
                If Not oFileDescriptor.ReferencedFileType = FileTypeEnum.kForeignFileType Then
                    Call ProcessReferences(oFileDescriptor.ReferencedFile, oDoc, oDocDef)
                End If
            Else
            Dim oComp As ComponentOccurrence
            For Each oComp In oDocDef.Occurrences
            If oComp.ReferencedDocumentDescriptor.ReferencedFileDescriptor.FullFileName = oFileDescriptor.FullFileName Then
            MsgBox (oFileDescriptor.FullFileName & vbCrLf & oFileDescriptor.RelativeFileName)
            'oComp.Delete
            End If
            Next oComp
            End If
        Next
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Hi Alex,
The aim is I'm looking for the solution of bigger iLogic rule / problem.
I've created the rule which is responsible for export of BOM to the excell file.
But this is not only simple export. In fact we need the data to be ready for print as a template we use.
So the rule sends BOM (row by row - missing content center parts or parts marked as "purchased") to the excell file
and then starts the macro which is responsilbe for sorting data to looks as we would like to.
Because at the end I would like to equipped all Inventor user with the rule, I'd like to be sure we are able to avoid any error situation.
Right now the rule works quite fine but there are two problematic situations:
1) When there are any missing parts (unresolved parts) within the assembly. Specialy when we share whole assemblies between users and some parts are missing during that process.
2) When the view representation is not set up as main
Below You can see the complete rule right now i have:
SyntaxEditor Code Snippet
Dim oDoc As Inventor.Document
'At first we're chcecking if opened file is an assembly or single part file. For single part system is running other rule.
If oDoc.DocumentType <> kAssemblyDocumentObject Then
    If oDoc.DocumentType = kPartDocumentObject Then
    UserChoice0 = MessageBox.Show ( "Czy chcesz wygenerowa� Kart� Ci�cia dla pojedy�czej cz�ci?", "iLogic",MessageBoxButtons.YesNo)
        If UserChoice0 = vbNo Then
        Exit Sub
        Else
        iLogicVb.RunExternalRule("Karta Ci�cia Cz��")
        Exit Sub
        End If
    End If
End If
'We're checking if the assembly file was already saved.
FilePath = ThisDoc.Path
    If FilePath = "" Then
    MessageBox.Show("Plik z�o�enia nie zosta� zapisany!" _
    & vbLf & " " _
    & vbLf & "Zapisz plik, nast�pnie uruchom regu�� ponownie.", "iLogic")
    Exit Sub
    End If
'Notification for user to be sure he would like to run the rule.
UserChoice2 = MessageBox.Show ( "Czy chcesz wygenerowa� Kart� Ci�cia?" _
    & vbLf & " " _
    & vbLf & "Upewnij si� �e wszystkie niezb�dne dane zosta�y uzupe�nione.", "iLogic",MessageBoxButtons.YesNo)
    If UserChoice2 = vbNo Then
    Exit Sub
    End If
'Input box to get user name
Opracowal = InputBox("Kart� Ci�cia Opracowa�:", "iLogic","Tomasz Pa�asz")
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oDoc.ComponentDefinition
'Below a peace of code to check if the detail representation - main is set up. Currently it doesn't work I don't know why?
    'Dim oLOD As LevelOfDetailRepresentation
    'Try
    'oLOD = oDoc.RepresentationsManager.LevelOfDetailRepresentations.Item("G��wna").Activate(True)
    'Catch
    'MessageBox.Show("Wyst�pi� problem z uaktywnieniem reprezentacji widoku - G��wna", "iLogic")
    'Exit Sub
    'End Try
'Below a peace of code to check if there are any unresolved parts within the assembly. If there are any it would be 'impossible to open BOM
Dim oRefFile As FileDescriptor
For Each oRefFile In oDoc.File.ReferencedFileDescriptors
    Dim AsmFilePath As String = oRefFile.FullFileName
    If Not System.IO.File.Exists(AsmFilePath) Then
    MessageBox.Show("Prawdopodobnie otwarte z�o�enie zawiera nierozwi�zane komponenty." _
    & vbLf & "Upewnij si� �e w z�o�eniu nie ma nierozwi�zanych komponent�w." _
    & vbLf & "Nast�pnie uruchom regu�� ponownie", "iLogic")
    Exit Sub
    Else
    End If
Next
'Now main part - which is responsible for BOM file export into an Excell file. After that the excell macro starts to sort the data within an excell file.
Dim oBOM As BOM
oBOM = oAsmCompDef.BOM
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Tylko Cz�ci")
oBOMView.Sort("Part Number", True)
oBOMView.Renumber(001)
Dim oBOMRow As BOMRow
'The rule checks for file path where an excell file is located.
Dim Filename As String = "C:\Users\Public\Documents\Autodesk\Inventor 2018\Templates\Karta Ci�cia Wz�r.xlsm"  '<---- TUTAJ ZMIE� �CIE�K� !
'If an excell file is already opened the rule will try to close it.
Try
    ObjXL = GetObject(Filename)
    ObjXL.Application.Quit
Catch
End Try
GoExcel.Open(Filename,"Arkusz2")
i=3
'The rule is counting total number of rows in the BOM
j=0
For Each oBOMRow In oBOMView.BOMRows
    If oBOMRow.BOMStructure <> 51973 Then
    Dim oCompDef As ComponentDefinition
    oCompDef = oBOMRow.ComponentDefinitions.Item(1)
    FullFileName  = oCompDef.Document.FullFileName
    Pozycja=InStrRev(FullFileName,"\", -1)
    NazwaModelu=Right(FullFileName,Len(FullFileName)-Pozycja)
    NumerCzesci=iProperties.Value(NazwaModelu, "Project", "Part Number")
    Opis=iProperties.Value(NazwaModelu, "Project", "Description")
'For every row in the BOM we're trying to catch custom iProperties vaulues
    Try
    Nazwa=iProperties.Value(NazwaModelu, "Custom", "Nazwa")
    Catch
    Nazwa=""
    End Try
    Try
    Rodzaj=iProperties.Material(NazwaModelu)
    Catch
    Rodzaj=""
    End Try
    Try
    Wymiar=iProperties.Value(NazwaModelu, "Custom", "Wymiar")
    Catch
    Wymiar=""
    End Try
    Try
    Uwagi=iProperties.Value(NazwaModelu, "Custom", "Uwagi")
    Catch
    Uwagi=""
    End Try
    Ilosc=oBOMRow.Totalquantity
    GoExcel.CellValue("B" & i)=Opis
    GoExcel.CellValue("C" & i)=NumerCzesci
    GoExcel.CellValue("D" & i)=Nazwa
    GoExcel.CellValue("E" & i)=Rodzaj
    GoExcel.CellValue("F" & i)=Wymiar
    GoExcel.CellValue("H" & i)=Uwagi
    GoExcel.CellValue("G" & i)=Ilosc
    i=i+1
    j=j+1
    End If
Next
'Based on total rows number the rule takes proper no. of excell sheet pages and sends it to the excell file.
    Select Case j
    Case 1 To 12
    Iloscstr = 1
    Case 13 To 24
    Iloscstr = 2
    Case 25 To 36
    Iloscstr = 3
    Case 37 To 48
    Iloscstr = 4
    Case 49 To 60
    Iloscstr = 5
    End Select
    Try
    Artykul = iProperties.Value("Project", "Stock Number")
    Catch
    End Try
    GoExcel.CellValue("A1")=iProperties.Value("Project", "Part Number")
    GoExcel.CellValue("B1")= Iloscstr
    GoExcel.CellValue("A2")= "Nr Art." & " " & Artykul
    GoExcel.CellValue("D1")=iProperties.Value("Project", "Description")
    GoExcel.CellValue("G1")= Opracowal
    GoExcel.DisplayAlerts = False
GoExcel.Save
GoExcel.Close
'Here the rule fires up the macro.
    Dim ExApp As Object
        ExApp = CreateObject("Excel.Application")
        Try 'Tutaj dodano fragment.
        For Each wb As Object In ExApp.workbooks
        If UCase(wb.fullname) = UCase(filename) Then
        'wb.Save
        wb.Close
        Exit For
        End If
    Next
Catch
Finally
    excelApp = Nothing
End Try  'Tutaj ko�czy si� dodany fragment.
        ExApp.workbooks.Open (Filename)
        ExApp.Application.Run ("KartaCieciaWzor")
        ExApp.Visible = False
        ExApp = Nothing
Dim Numer As String
'The rule tries to check if the end excell file was properly created and saved.
Numer = "C:\Users\t.palasz\Desktop\Karty Ci�cia\" & iProperties.Value("Project", "Part Number") & ".xlsx" '<---- TUTAJ ZMIE� �CIEK�
If System.IO.File.Exists(Numer) Then
    UserChoice3 = MessageBox.Show ("Karta Ci�cia zosta�a wygenerowana pomy�lnie!" & vbLf & " " & vbLf & "Czy chcesz otworzy� Kart� Ci�cia?", "iLogic",MessageBoxButtons.YesNo)
        If UserChoice3 = vbYes Then
        ThisDoc.Launch(Numer)
        Exit Sub
        Else
        Exit Sub
        End If
    Else
    MessageBox.Show("Upss... Co poszo nie tak!", "iLogic")
    Exit Sub
    End If
AlexFielder
Hi @Anonymous,
Thanks for the detailed explanation and code sample.
I can see now why you want to remove unresolved components. I agree that if it's going to cause the exported BOM process to fail then you'd be correct to remove them.
BUT (And it's a big but!), it would seem to me to be a better question/solution if you were able to address why you are seeing unresolved components.
Typical reasons for this are (and I'm sure someone else will add to this list if I miss anything):
  1. Assemblies not saved in consistent network paths i.e. some users have Z:\path\to\assembly whereas others may have \\servername\zdriveroot\path\to\assembly or a mixture of both.
  2. Users creating assemblies locally on C: and not sharing all files.
  3. Users creating assemblies locally and not using/being aware of "Pack & Go" to grab all referenced files.
  4. (and by no means least) users working on assemblies locally and not setting the correct project file.
  5. Inconsistent naming of part files (user A creates a new part called "widget", user then creates another part called "widget" using a different project file and (after sharing the assembly) when a different user opens the assembly they get prompted as to which they want to use and choose neither.
So really this boils down to:
a) Do you use Vault? All versions provide unique naming checks which can prevent users checking in multiple parts called "widget" or whatever. Vault also allows enforcement of a common project file for all users.
b) Are your team trained sufficiently that they're aware of the company's unique naming/path conventions?
c) Is any of ^ documented (for new/existing users)?
Since you're here and asking for help on this, there are steps you can take whilst you get a thru c above sorted out.
The first of which would be put together (or update) a document showing what is stored where on your network as well as the reason for it's importance in getting paths correct (point them to this post if necessary).
Second, I would think about changing your iLogic rule above such that when it finds an unresolved file to flag to the user the points I noted above, such that they can set the correct project file, check they received a complete pack & go and/or are using the correct file paths etc. etc.
Third, if you have users (even especially those who are self-taught!) who haven't been trained (or trained recently) I would heartily recommend you seek out the services of your local Autodesk reseller who will be more than happy to help.
Full disclosure: I work for a reseller here in the UK, so have trained Inventor users on both the main product, as well as iLogic in the past and the unresolved file problem typically stems from the issues I touched on above.
Apologies for the wall of text, but I hope it gives you food for thought.
Cheers,
Alex.
AlexFielder
PS. I would recommend that if you insist on continuing to delete unresolved files, that you wrap the whole method in a transaction, thereby giving the user a chance to undo the whole thing, otherwise (if there are a lot) it'll be a painful process to sit and click "Undo" repeatedly:
Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(oAssemblyDocument, "Clean up unresolved files")
Try
    'Do Stuff
    trans.Commit()
Catch 'any errors
    trans.Abort()
End Try
:slightly_smiling_face:
Hi Alex,
Thanks for fast reply and a bounch of information.
In fact our team use the Vault aplication and we're working only on single project file.
So problem with unresolved files occures really rarely.
But because I would like to be sure my rule works 100% reliably before I'll redistribute it to all users I need to check if it would work with all our files.
Right now it looks not bad but there are still two problems I've mantioned above.
One with unresolved files (most of them are parts from content center library - If anybody uses different from project library). I'm wondering about using the snippet of code given by frederic but I'm not sure which part I can cut to adapt the code to iLogic syntax.
Second one is problem with switching the view representation into main.
Now I have a piece of code wich should be able to do that but it's not working.
    Try
    Catch
    Exit Sub
    End Try
Hi Frederic,
I've made some small adjusments to adopt syntax to iLogic and now it works great.
Thanks a lot for help.
Best Regards
Jason.Rugg
@Anonymous @frederic.vandenplas  I have the need to delete unresolved references as well, can you share the ilogic code you made to do this?
Please try this snippet:
oFile = oAsmDoc.File
End If
Else
For Each oComp In oAsmCompDef.Occurrences
oComp.Delete
I hope You'll find it helpful
Regards
Tomek
