iLogic: Change texture file path
renanmaronni
renanmaronni
I'm trying to update the texture file path via iLogic but I can't find anywhere a method to do that.
Here a print from what value I want to change.
How could I change this value? Thank you very much.
WCrihfield
ThisApplication.FileOptions.TexturePath = 'your path to the folder
Edit:  I responded too fast.  That is how you set the setting on the File tab of the Application Options dialog, about where your default Textrue folder is located.
Wesley Crihfield
(Not an Autodesk Employee)
renanmaronni
Thank you for your reply.
But what I'm trying to do is change the texture file, and not the texture files folder. The specific texture file of this appearance.
Michael.Navara
This part of API is not well documented. But here is the code sample, how to access this value. Perhaps it can be simplified or improved
Dim part As PartDocument = ThisDoc.Document
Dim activeAppearance As Asset = part.ActiveAppearance
For Each assetValueInActiveAppearance As AssetValue In activeAppearance
    Dim colorAssetValue As ColorAssetValue = TryCast(assetValueInActiveAppearance, ColorAssetValue)
    If colorAssetValue Is Nothing Then Continue For
    If colorAssetValue.Name <> "generic_diffuse" Then Continue For
    Dim connectedTexture As AssetTexture = colorAssetValue.ConnectedTexture
    For Each assetValueInConnectedTexture As AssetValue In connectedTexture
        Dim filenameAssetValue As FilenameAssetValue = TryCast(assetValueInConnectedTexture, FilenameAssetValue)
        If filenameAssetValue Is Nothing Then Continue For
        If filenameAssetValue.Name <> "unifiedbitmap_Bitmap" Then Continue For
        Logger.Debug(filenameAssetValue.Value)
        'Value is read/write
        'filenameAssetValue.Value = "C:\path\to\your\texture.jpg"
        Exit Sub
    Next
Next
renanmaronni
Thank you very much, it worked.
