iLogic Can't find Excel sheet
Daan_M
Daan_M
Solved, apologies i cant remove the post.
marcin_otręba
could you share your code here ?
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Daan_M
I solved it in the meantime, it's very strange....
I use iLogicAutomation in my C# script to trigger one specific rule.
In my assembly i have 3 rules, "cmdRead", "cmdReadLos" and "2D pdf". For some reason my script triggered both "cmdRead" and "cmdReadLos", the strange part is rule "2D pdf" doesn't get triggered. I think maybe because the names  of the rules are partially identical, it causes this problem.
Either way, supressing the one i dont use works.
