[iLogic] Can't create a new folder on a server drive
mhoE3YPJ
mhoE3YPJ
I've been tweaking a .dxf export rule, and I've ran into a problem.
I can't create the folder on our server drive. Its a seperate server, and I'm pretty sure,
I have admin access.
The thing is that I can manually create a folder, with the right name, and then the files,
will be able to save to that folder.
The variale aOrdreNr is a userparameter, I have in my assembly. Its put as unitless.
Is there a way to get around this problem?
Mind you, this works if I use the C: drive, as path.
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
If oDoc.DocumentType <> kAssemblyDocumentObject Then
    MessageBox.Show("Denne funktion SKAL køres i Assembly fil", "DABO")
    Exit Sub
End If
RUsure = MessageBox.Show ( _
"Denne funktion vil lave DXF Filer af alle dele i samlingen." _
& vbLf & " " _
& vbLf & "Sørg for at funktionen GEM ALLE SOM KOPI har kørt inden denne funktion." _
& vbLf & "Denne funktion kan tage tid. Din mappe bliver vist tilsidst.", "DABO Export DXF ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
    Return
 Else
End If
oPath = ("C:\Gulvsug\" & aOrdreNr & "\")
Dim oRefDocs As DocumentsEnumerator
Dim oRefDoc As Document
oRefDocs = oDoc.AllReferencedDocuments
For Each oRefDoc In oRefDocs
    Dim oCurFile As Document 'current file
    Try
        oCurFile = ThisApplication.Documents.Open(oRefDoc.FullFileName, False)
     Catch
        GoTo NextIteration
    End Try
    If oCurFile.DocumentSubType.DocumentSubTypeID <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
        oCurFile.Close(True)
    Else
        oCurFileName = oCurFile.FullFileName
        FNamePos = InStrRev(oCurFileName, "\", -1)
        FName = Right(oCurFileName, Len(oCurFileName) - FNamePos)
        FName = Left(FName, Len(FName) - 4)
        DxfName = oPath & aOrdreNr & "-" & aOrdrePre & " " & FName & ".dxf"
        Dim oSMCD As SheetMetalComponentDefinition = oCurFile.ComponentDefinition
        If Not oSMCD.HasFlatPattern Then
            oSMCD.Unfold()
            oSMCD.FlatPattern.ExitEdit()
        End If
        Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2004" _
            + "&OuterProfileLayer=IV_INTERIOR_PROFILES" _
            + "&InvisibleLayers=IV_TANGENT;IV_FEATURE_PROFILES_DOWN;IV_BEND;IV_BEND_DOWN;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL" _
            + "&SimplifySplines=True" _
            + "&BendLayerColor=255;255;0"
        Try
            oSMCD.DataIO.WriteDataToFile(sOut, DxfName)
         Catch
        End Try
    End If
    NextIteration:
Next
MessageBox.Show("Alle DXF Filer exporteret til: " & vbLf & oPath & vbLf & vbLf & "Tjek venligst filerne, inden brug.", "DABO")
Shell("explorer.exe " & oPath,vbNormalFocus)
Ralf_Krieg
Hello
I can't see any line where you create the directory. *???*
You can test if directory exist and create otherwise. If creation fails, you can exit your sub
Dim sPath As String = "C:\Gulvsug\" & aOrdreNr & "\"
Dim oDirInfo As System.IO.DirectoryInfo
If Not System.IO.Directory.Exists(sPath) Then
	oDirInfo = System.IO.Directory.CreateDirectory(sPath)
	If oDirInfo Is Nothing Then
		MsgBox("Error creating Directory " & sPath, , "iLogic DXF-Export")
		Exit Sub
	End If
End If
R. Krieg
RKW Solutions
www.rkw-solutions.com
mhoE3YPJ
I got an error, from the line, where it pulls on the directoryInfo,
but insted I tweaked it a little and now it works.
If System.IO.Directory.Exists(oPath) = False Then
	System.IO.Directory.CreateDirectory(oPath)
ElseIf System.IO.Directory.Exists(oPath) = True Then
End If
Thanks for the help!
ChristianAndersenIsmyname
End If
You can save yourself some lines with this instead:
If System.IO.Directory.Exists(oPath) = False Then System.IO.Directory.CreateDirectory(oPath)
Also, where are to defining what aOrdreNr is?
Don't you need to have something like this before you define oPath?
aOrdreNr = iProperties.value("Project","Stock Number")
mhoE3YPJ
Thanks for the tip!
As I think I stated before, aOrdreNr is a userparameter in my assembly file.
I use a form, as seen below, where I change userparameters, and update my assembly.
After which I'll make the .dxf files.
I get that it doesn't look that pretty, but it's very efficient, as to I usually have an excel document, with linked
parameters, and I usually save my .dxf files manually.
I dont know if there's an easy way to make an input for iProperties in forms?
Sorry, I missed that you stated it in your post :slightly_smiling_face:
For iProperties input: Is this what you're after?
mhoE3YPJ
Somehow I've completly missed that :grinning_face_with_sweat:
I'm somewhat new to the whole iLogic department,
but I think if I use the iProperties, it'll make it look a lot more clean.
Thanks for the nice idea! I'll update when I've added them :grinning_face_with_smiling_eyes:
