iLogic - Break link to all base components from Top level assembly
Hi All,
i am writing an iLogic script to run from a top level assembly that will go through all sub assemblies and their respective parts and break the link to all components that have a link to a base component.
This is what i have so far but it just keeps locking up and crashing my Inventor 2021
Sub Main()
Dim assm As AssemblyDocument
assm = ThisApplication.ActiveDocument
Dim occ As ComponentOccurrence
Dim derpart As DerivedPartComponent
Dim partdoc As PartDocument
'it f you want to use all components'
Dim doc As AssemblyDocument = ThisDoc.Document
Dim oLOD As LevelOfDetailRepresentation
Dim oAsmCompDef As ComponentDefinition
oAsmCompDef = doc.ComponentDefinition
Try
oLOD = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Item("Master").Activate(True)
Catch
Dim nLOD As LevelOfDetailRepresentation
nLOD = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Add("Master")
oLOD = nLOD
Finally
End Try
For Each occ In assm.ComponentDefinition.Occurrences
    If occ.DefinitionDocumentType = kPartDocumentObject Then
    For Each derpart In occ.Definition.ReferenceComponents.DerivedPartComponents
        derpart.BreakLinkToFile
        iLogicVb.UpdateWhenDone = True
    Next
ElseIf occ.DefinitionDocumentType = kAssemblyDocumentObject Then
Call processAllSubOcc(occ) ' subassembly
 End If
Next
End Sub
'' This function is called for processing sub assembly. It is called recursively
'' to iterate through the entire assembly tree.
Sub processAllSubOcc(ByRef occ As ComponentOccurrence)
Dim oSubCompOcc As ComponentOccurrence
    For Each oSubCompOcc In occ.SubOccurrences
    ' Check if it's child occurrence (leaf node)
        If oSubCompOcc.DefinitionDocumentType = kPartDocumentObject Then
        For Each derpart In oSubCompOcc.Definition.ReferenceComponents.DerivedPartComponents
        'My Code
        Next
        End If
    Next
End Sub
JhoelForshav
Hi @Anonymous
I think this should be enough? :slightly_smiling_face:
Dim oAsm As AssemblyDocument = ThisDoc.Document
For Each oDoc As Document In oAsm.AllReferencedDocuments
	If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject AndAlso oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc).Count > 0
		For Each derComp As DerivedPartComponent In oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents
			derComp.BreakLinkToFile
		Next
	End If
Next
