Ilogic Bill of Material Item Numbers
ryangardner
ryangardner
I'm currently using I-logic to suppress and unsuppress parts (IPT) in an assembly. Is there anyway in this assembly if I can assign a Bill of material item number and it will stay with that part (IPT) once it is turned back on (unsuppressed) back into the assembly? To get more of an understanding of what I'm doing. This assembly also has I-logic built into the drawing for this assembly. In this drawing, I turn view's on/off as the part gets suppressed and the view isn't needed. Currently the model is assigning a new item number once the part is unsuppressed back into the assembly. Therefore, I have to change the view title. Thanks for your help!
Can you change the view title to reference something other than the BOM item number? A part #, stock # or description perhaps? Might take some change to the code, but these will stay the same.
Hope this helps!
ryangardner
I've thought of this at one point. I use the item # in the bill of material to call out the view. Thanks though!!
lena.talkhina
Hello @ryangardner !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. :slightly_smiling_face:
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
