iLogic AutoComplete Type Feature
matt_jlt
matt_jlt
I was wondering if iLogic had the same type of AutoComplete feature that VBA has where if you type in oDoc for example, you get the little list box that pops up and you can select the next reference eg. "ComponentDefinition".
It's a really handy feature and i'd like to know if it's possible beacuse currently i just write my code in VBA and paste it into ilogic or vb.net and tweak it to suit.
I have looked for the option but have not found any information on it, I think i might need to add a reference to the object library or something along those lines?
Any help is much appreciated.
Thanks, Matt.
MjDeck
Sorry, AutoComplete or Intellisense is not available in iLogic.   What you're doing now is the best workaround available: develop in VBA or VB.NET and then copy and paste the code to iLogic.
Mike Deck
Software Developer
Autodesk, Inc.
matt_jlt
Thanks for your reply, bit of a bummer though. It would be a great feature to add as it can be a bit painful continuously going back and forth between vba and ilogic.
Cheers, Matt.
