iLogic Appearance of all occurrences in an Assembly
fce
fce
Hello there,
I would like to open each occurrence in an already open top assembly and get each appearance as a string.
I'm aware that the command "iProperties.PartColor" allows you to get the Appearance, but it's not working running from the top assembly. I'm probably just missing a simple function. Bellow you can find the code:
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = ThisDoc.FileName(False) 'without extension
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the referenced models
For Each oRefDoc In oRefDocs
    Dim oCurFile As Document
    oCurFile = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
			oCurFileAppearance = iProperties.PartColor
			'oCurFileAppearance= oCurFile.Definition.Document.ActiveRenderStyle
			MessageBox.Show(oCurFileAppearance, "oCurFileAppearance")
			If oCurFileAppearance = "-"
			oCurFileAppearance ="-"
			End If
'			MessageBox.Show(oCurFileAppearance, "oCurFileAppearance")
oCurFile.Close
Next
JhoelForshav
@fce
Just to make sure - Do you want the appearance of the document or the occurrence?, beacuase those are not always the same :slightly_smiling_face:
fce
Good question. I would like to get the appearance of each ipt. and .iam opened in the "For" cycle.
The appearance that shows on the top of Inventor WIndow.
JhoelForshav
@fce
Those are actually two different things (iam and ipt). For an iam, the appearance shown in that dropdown is the appearance set to the selected occurrence in that assembly. The appearance in the document can be something else. So an assembly document in itself can't have an active appearance, only the occurrences of that assembly.
Do I make any sense to you? :grinning_face_with_smiling_eyes:
This code however will give you the active appearance of all parts :slightly_smiling_face:
Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
Dim oAppearances As String = "Appearances:" & vbCrLf
For Each oRefDoc As Document In oAsmDoc.AllReferencedDocuments
If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject
	Dim oAppearance As String = DirectCast(oRefDoc, PartDocument).ActiveAppearance.DisplayName
	oAppearances = oAppearances & vbCrLf &  oRefDoc.DisplayName & "	" & oAppearance
End If
Next
MessageBox.Show(oAppearances, "Appearance list")
fce
Nice, it worked perfectly. Thanks a lot!
_KarlH
Thanks for sharing that example. I'm attempting to modify the loop so that it can change all the colours within an Assembly at the Part level.
My initial attempt simply re-named the active Color within the Part but unfortunately didn't change the Colours appearance.
		DirectCast(oRefDoc, PartDocument).ActiveAppearance.DisplayName = "Cyan"
	End If
Next
Using the likes of Component.Color only creates an assembly appearance overide on the active view rep, which is why I can't use the below;
Component.Color("Example_Part:1") = "Red"
Would appreciate any help on having assembly level iLogic code change a parts Appearance at the part level.
