- Mute
- Permalink
- Report
Hi I'm new in ilogic (1 day experience) there is any way to run ilogic to standard part?
Hi @k.grigoriou . Any files in "Content Center Files" cannot be modified, including iLogic rules cannot be run. But you can add a rule to the template file from the library and set the event to fire before the file is saved. In this way, your rule will be executed once and the file will be saved to the Content Center.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
