ilogic and composite imate suppress issue
jletcher
Advisor Advisor
jletcher
I have an issue with this not sure what because it works one way but not back...
 I have two composite constraints on the same part one gets suppressed when option is true and changes to the other if false.
True puts sprocket in center (iComposite:6) false moves sprocket to iComposite:5 or it should but error.
 It works one way but not the other way. If I pick true it works if I pick false it fails..
 Any idea?
 Here is code and error.
If Sprocket_Center = True Then
	Parameter("Master Drive:1", "Sprocket_Center") = True
	Constraint.IsActive("iComposite:5") = False
	Constraint.IsActive("iComposite:6") = True
Else
	Parameter("Master Drive:1", "Sprocket_Center") = False
	Constraint.IsActive("iComposite:5") = True
	Constraint.IsActive("iComposite:6") = False
  Thanks For your help..
jletcher
  Ok I figured it out I had to change the Else part
 I had to move line with iComposite:5 below iComposite:6
 Now it works Smiley Surprised
