if an ilogic is work, what can make it fail getting data for an excel ark?
Darkforce_the_ilogic_guy
i have 10 computer runne an ilogic code.. on 9 computer it work fine. all computer run on windows 10 and have inventor  2018.3.6. All the files that are use ... templet , ilogic and excel fil are computer from the same vault . all files seens to be up to date. the code have work more the 2 years.. and one day it just stop working on 1 computer.
Does anyone have an ideer why and how to fix it ?
JhoelForshav
Hi @Darkforce_the_ilogic_guy
Do you use the GoExcel-functions? If so i think you shoud check this thread out.
https://forums.autodesk.com/t5/inventor-customization/problem-with-goexcel-findrow/td-p/6987941
As explained there GoExcel is a bit unstable and errors may occure with it on some computers (estimated 1/10 in the thread).
Hopefully you can adapt the solution presented there.
