Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
I need to rewrite VBA to ilogic sort partlist
2 REPLIES 2
Darkforce_the_ilogic_guy
241 Views, 2 Replies
I have an ilogic code and a VBA that I use today. I would like to rewrite it to one Ilogic code?
the ilogic code is this
Try
Dim SheetsNumber
SheetsNumber = ThisApplication.ActiveDocument.Sheets.Count
For i = 1 To SheetsNumber
Dim oPartslistCheck As PartsList
oPartslistCheck = ThisApplication.ActiveDocument.Sheets(i).PartsLists(1)
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Call oDoc.SelectSet.Select(oPartslistCheck)
InventorVb.RunMacro("ApplicationProject", "PartsListSort", "FormatSelectedPartsList")
Next
Catch
End Try
and the VBA code
Option Explicit
Option Base 1
Public Function GetActiveDrawing() As DrawingDocument
If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
Set GetActiveDrawing = ThisApplication.ActiveDocument
Else
MsgBox "Must have a drawing active", vbOKOnly, "Error"
End Function
Public Function GetSelectedPartsList() As PartsList
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = GetActiveDrawing
If oDrawDoc Is Nothing Then Exit Function
Dim oSelectSet As SelectSet
Set oSelectSet = oDrawDoc.SelectSet
If oSelectSet.Count = 0 Then Exit Function
If oSelectSet.Item(1).Type <> kPartsListObject Then Exit Function
Set GetSelectedPartsList = oSelectSet.Item(1)
End Function
Public Function FormatPartsList(oPartsList As PartsList) As PartsList
On Error Resume Next
oPartsList.Sort "PART NUMBER", True
oPartsList.Renumber
oPartsList.SaveItemOverridesToBOM
If Err Then
Err.Clear
MsgBox "Could not sort Parts List", , "Error"
Set FormatPartsList = oPartsList
End Function
Public Sub FormatSelectedPartsList()
Dim oPartsList As PartsList
Set oPartsList = GetSelectedPartsList
If oPartsList Is Nothing Then Exit Sub
FormatPartsList oPartsList
End Sub
2 REPLIES 2
I don't test it, but I hope it works
Sub Main()
    Try
        Dim drawing As DrawingDocument = ThisApplication.ActiveDocument
        Dim sheetsNumber = drawing.Sheets.Count
        For i = 1 To sheetsNumber
            oPartslistCheck = drawing.Sheets(i).PartsLists(1)
            oDoc = drawing
            'InventorVb.RunMacro("ApplicationProject", "PartsListSort", "FormatSelectedPartsList")
        Next
    Catch
    End Try
End Sub
#Region "VBA to iLogic"
'Option Explicit
'Option Base 1
    If ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
    Else
        MsgBox("Must have a drawing active", MsgBoxStyle.OkOnly, "Error")
End Function
    oDrawDoc = GetActiveDrawing()
    If oSelectSet.Item(1).Type <> ObjectTypeEnum.kPartsListObject Then Exit Function
End Function
    oPartsList.Sort ("PART NUMBER", True)
    oPartsList.Renumber()
    oPartsList.SaveItemOverridesToBOM()
    If Err() Then
        Err.Clear()
        MsgBox ("Could not sort Parts List", MsgBoxStyle.OkOnly , "Error")
End Function
    FormatPartsList (oPartsList)
End Sub
#End Region
I did need to delete this code
If Err() Then
        Err.Clear()
but the rest works
