I need to make a check if partlist is already sorted?
Darkforce_the_ilogic_guy
I need to make a check if partlist is already sorted?  I have this problem  I want the partlist to be sorted.
My problem is If  I on save does a Save item ovverides to bom. It will show like the iam have not save the lates changes
but I don´t the partlist show this lighning ,
Any idear how to fix this. ? I think if might be fix if it only do the Save item ovverides to bom if there is any change  to the partlist if it is not sorted as it should be.. so I could simple dobble save.  but i am open to idears to fix it.. this is current code  (it will not run with the Save item ovverides to bom on our test users but all users not call JCM or jcm will run the Save item ovverides to bom command
Sub Main()
    Try
        Dim drawing As DrawingDocument = ThisApplication.ActiveDocument
        Dim sheetsNumber = drawing.Sheets.Count
        For i = 1 To sheetsNumber
            Dim oPartslistCheck As PartsList
            oPartslistCheck = drawing.Sheets(i).PartsLists(1)
            Dim oDoc As DrawingDocument
            oDoc = drawing
            Call oDoc.SelectSet.Select(oPartslistCheck)
            'InventorVb.RunMacro("ApplicationProject", "PartsListSort", "FormatSelectedPartsList")
            FormatSelectedPartsList()
        Next
    Catch
    End Try
End Sub
#Region "VBA to iLogic"
'Option Explicit
'Option Base 1
Public Function GetActiveDrawing() As DrawingDocument
    If ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
        GetActiveDrawing = ThisApplication.ActiveDocument
    Else
        MsgBox("Must have a drawing active", MsgBoxStyle.OkOnly, "Error")
    End If
End Function
Public Function GetSelectedPartsList() As PartsList
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = GetActiveDrawing()
    If oDrawDoc Is Nothing Then Exit Function
    Dim oSelectSet As SelectSet
    oSelectSet = oDrawDoc.SelectSet
    If oSelectSet.Count = 0 Then Exit Function
    If oSelectSet.Item(1).Type <> ObjectTypeEnum.kPartsListObject Then Exit Function
    GetSelectedPartsList = oSelectSet.Item(1)
End Function
Public Function FormatPartsList(oPartsList As PartsList) As PartsList
oNAME = ThisApplication.GeneralOptions.UserName
    On Error Resume Next
    oPartsList.Sort ("PART NUMBER", True)
    oPartsList.Renumber()
	If oNAME = "jcm" Or oNAME = "JCM"  Then
	Else
		 oPartsList.SaveItemOverridesToBOM()
	End If
    FormatPartsList = oPartsList
End Function
Public Sub FormatSelectedPartsList()
    Dim oPartsList As PartsList
    oPartsList = GetSelectedPartsList
    If oPartsList Is Nothing Then Exit Sub
    FormatPartsList (oPartsList)
End Sub
#End Region
Replies (0)
