I NEED HELP TO DISABLE THESE THESE OPTIONS AS YOU SEE IN THE IMAGE WHEN YOU RIGHT CLICK ON THE RULES
deepak_bs
deepak_bs
Hello Everyone,
I use Inventor 2022, I am trying to disable the Options - 'Run Rule' , 'Edit Rule' , 'Regenerate Rule' , 'Copy' , 'Unsuppress Rule' & 'Delete' when we right click on the rules in I-logic Section. I need help how to do this. So that i can Protect my rules by Copying, Opening, Editing, Deleting etc. I even Created a Add-in using Vb.net coding in Visual Studio 2022 , but my Inventor 2022 is not launching that add-in. Its failing to Recognize the Add-in. Please help me with the ways i can achieve this.
C_Haines_ENG
You cant protect your iLogic rules, you Either need to create an Add-In or make them in Macros.
