I-Logic for Custom properties
didin.suryadi6JREK
didin.suryadi6JREK
Hello
Can anyone check below i-logic code?
Dim propertyName1 As String = "Rev Desc"
Dim propertyValue1 As String = ""
customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Try
      prop = customPropertySet.Item(propertyName1)
Catch
      customPropertySet.Add("", propertyName1)
  End Try
	Dim propertyName2 As String = "Rev Date"
Dim propertyValue2 As String = "mm/dd/yyyy"
Try
      prop = customPropertySet.Item(propertyName2)
Catch
      customPropertySet.Add("mm/dd/yyyy", propertyName2)
  End Try
	Dim propertyName3 As String = "Salvagnini Proficient"
Dim propertyValue3 As String = "Yes"
Try
      prop = customPropertySet.Item(propertyName3)
Catch
      customPropertySet.Add("Yes/No", propertyName3)
  End Try
The problem on the result i have is the "Rev Date" shown as text meanwhile the purpose i need is "Date"
and the 2nd one on string "Salvagnini proficient" it's needs to be a multpile choices 'YES'NO"
Please see attached the wrong result and what i need.Custome Properties (wrong).JPG
Replies (13)
JhoelForshav
Hi @didin.suryadi6JREK
You must use a value of the datatype expected by the property type you want it to be.
For example, if you want a date property, the value must be of a date type.
Dim customPropertySet As PropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Try
Catch
End Try
Dim propertyValue2 As Date = Today.Date
Try
Catch
	customPropertySet.Add(propertyValue2, propertyName2)
End Try
Dim propertyValue3 As Boolean = True
Try
Catch
	customPropertySet.Add(propertyValue3, propertyName3)
End Try
Pulled directly from the API help file.
Public Sub CreateCustomProperties()
    ' Get the active document.
    Dim invDoc As Document
    Set invDoc = ThisApplication.ActiveDocument
    ' Get the user defined (custom) property set.
    Dim invCustomPropertySet As PropertySet
    Set invCustomPropertySet = invDoc.PropertySets.Item("Inventor User Defined Properties")
    ' Declare some variables that will contain the various values.
    Dim strText As String
    Dim dblValue As Double
    Dim dtDate As Date
    Dim blYesOrNo As Boolean
    ' Set values for the variables.
    strText = "Some sample text."
    dblValue = 3.14159
    dtDate = Now
    blYesOrNo = True
    ' Create the properties.
    Dim invProperty As Property
    Set invProperty = invCustomPropertySet.Add(strText, "Test Test")
    Set invProperty = invCustomPropertySet.Add(dblValue, "Test Value")
    Set invProperty = invCustomPropertySet.Add(dtDate, "Test Date")
    Set invProperty = invCustomPropertySet.Add(blYesOrNo, "Test Yes or No")
End Sub
For a yes/no custom iProperty you will need to provide a variable with a boolean type.
Best of luck!
didin.suryadi6JREK
HI,
I tried but came up msg error, why is that?
didin.suryadi6JREK
hi
Thanks, but the same error msg came up
didin.suryadi6JREK
HI, THIS IS WHAT AM TALKING ABOUT, THANKS
IT's WORKED.
robertast
 @Anonymous      You have provided an example that runs VBA makro and you are trying to write it to iLogic. As a result, you get an error. Replace "Public Sub CreateCustomProperties ()" with "Sub main ()". And everywhere there is the word “Set”. Erase them.
And just read all @JhoelForshav  posts in this forum and you will find a lot of interesting and useful :thumbs_up:
didin.suryadi6JREK
Hi
Just come up with another question, what string do i have to put on "Rev Date" if i want it to leave empty on the first entry value, so it will be filled when we do the revision.
  Attached the final result that i wanted.
didin.suryadi6JREK
Hi
Thanks for your correction, would you please take a look to my latest reply? on "Rev Date" i want it to leave empty on the first entry value, so it will be filled when we do the revision.
I have attached on replied with the pic that i wanted.
Appreciated your prompt reply.
robertast
Do you use code written by  @JhoelForshav  ?
He will stop sleeping and write you an answer. If you're having trouble waiting, :slightly_smiling_face:
try changing
"Dim propertyValue2 As Date = Today.Date"
to      Dim DimValue2 As Date = " "
didin.suryadi6JREK
Hi Rob
sorry for hurry, he is sleeping and will read by tomorrow, so do i.
Anyway i tried with your suggestion and it looks like the string did not match,
See Attached
robertast
Forgive me  @JhoelForshav  because I was a bad student, giving the wrong advice. :slightly_frowning_face:
JhoelForshav
The only way I can get this to work is to create the property with a date, then make it Null. Like this :slightly_smiling_face:
Try
Catch
End Try
Dim propertyValue2 As Nullable(Of Date) = Date.Now
Dim NullDate As Nullable(Of Date)
Try
Catch
	iProperties.Value("Custom", propertyName2) = NullDate
End Try
Try
Catch
End Try
didin.suryadi6JREK
Waw,,.. Its working now,
Thank You very much sir, have a good day
