How to use embedded excel file
Hi
I have used the command "insert object" to embed an excel sheet. I can see in the modelbar the new stage called "3rd Party", expanded I also see "Embedding 1". If I use edit I can se my excel sheet. So far good.
My next task is to creat a Rule to recall cells in the sheet. I use the command CellValue (embedded) to pick my cell value. My problem is that then I close my rule-editor I got the error:
Error in rule: Rule0, in document: Box test.ipt
GoExcel: 3rd Party worksheet not found: "3rd Party:Embedding 1", Sheet: "Sheet1"
It seems like I´m not able to recall my cellvalues. Whats wrong?
Whats the diffrens between embedding a excelsheet as above or use the add link command i Parameters window?
BR/Goran
