How to use ApprenticeServerComponent and ApprenticeServerDocument in .Net classlibrary(c# dll)
vijaykumarreddy25
vijaykumarreddy25
Please provide solution for how to use ApprenticeServerComponent and ApprenticeServerDocument in .Net classlibrary(c# dll).
My requirement is to open document using ApprenticeServerComponent in .Net classlibrary(c# dll).
Thanks & Regards,
Vijay
pcrawley
You might have more luck reposting over on the customisation forum here:
Inventor iLogic and VB.net Forum - Autodesk Community
One of the forum moderators can move this post for you.
Peter
JelteDeJong
You might want to look at this post "iProperties Without Inventor (Apprentice)". In the post, they use vb.net. I translated to C# (but did not test it.) it looks something like this:
Inventor.ApprenticeServerComponent apprentice = new Inventor.ApprenticeServerComponent();
Inventor.ApprenticeServerDocument apprenticeDoc = apprentice.Open(Filename);
Inventor.PropertySet summaryPropSet = apprenticeDoc.PropertySets["Inventor Document Summary Information"];
Inventor.Property companyProp = summaryPropSet["Company"];
companyProp.Value = "www.hjalte.nl";
apprenticeDoc.PropertySets.FlushToFile();
apprenticeDoc.Close();
Jelte de Jong
Blog: hjalte.nl - github.com
vijaykumarreddy25
Thank you for your response JelteDeJong.
The above code it is working fine for Console Application(C#) or Windows Application(C#).
But in class library (dll) it is not working.
Can you please let me know is there any solution is there to execute in class library (dll).
Thanks & Regards,
Vijay
jjstr8
Is the platform target for your application using the DLL set to x64? It cannot be 'Any CPU'
Edit:  Just to clarify, it can't be 'Any CPU' with 'Prefer 32-bit' checked (which is the default).  So either unchecking 'Prefer 32-bit' with 'Any CPU' or selecting x64 will work.
