Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Is it possible to stop an infinite loop when running an iLogic rule?
Pascal Langlais
Solved by MjDeck. Go to Solution.
@arron.craig, do you have Visual Studio installed? If so you can use it to attach to the Inventor 2019 process and then "Break All". This will most likely jump right to your rule code in Visual Studio. You might be able to break out of the loop that's currently running. And if you can't break out, you can at least step though the statements in the loop to find out why it's stuck.
I figured it out. The vb file is stored in
appdata\Local\Temp\iLogic Rules
if its not there, go back to \Temp and find the most recent .out (moldDesignFileHandler) file and open it in visual studio. this gave me the location where all of my inventor vb files were saved.
this just saved me a days worth of work
hope this helps
inventor professional 2019
@Leonardo_Czuy , in Inventor 2023 and 2024 there is no easy way to stop an infinite loop. However, if you have Visual Studio you can attach to the Inventor process and debug to try to find out why the rule is stuck in a loop.
If you know that a loop might run too long (or forever) in some situations, you can add code to check if a key is down and exit the loop in that case. See the attached rule for a sample. With that Keyboard class in your rule, you would add checking code such as the following in each loop:
ThisApplication.UserInterfaceManager.DoEvents
Dim keyDown = Keyboard.IsKeyDown(Keys.ShiftKey)
If keyDown Then
Logger.Debug("shift key down = {0}. Exiting loop.", keyDown)
Exit For ' use Exit Do for Do loops, or Exit While for While loops
End If
iLogic debug is available since 2019 with VS:
https://modthemachine.typepad.com/my_weblog/2019/12/using-visual-studio-to-debug-ilogic-rules.html
Just tested with VS2022 Community on IV2023.
I agree that iLogic is not supposed to be a complete end-all-be-all programming tool, but any development environment with the ability to form inescapable "do while" loops really ought to have some kind of Keyboard shortcut to act as a sequence breaker, regardless of scope. To not have this tool available feels grossly negligent.
Going to pass on some amazing knowledge I was given awhile back when I ran into an infinite loop myself. If you know you're going to be testing a loop or know that it could end up in an endless state use the following code.
oFile = "C:\Temp\Endless Loop Saftey File.txt"
If IO.File.Exists("C:\Temp\Endless Loop Safety File.txt") = False Then
MsgBox("The rule called '" & iLogicVb.RuleName & "' stopped because text file doesn't exist:" & vbLf & oFile, , "iLogic")
Exit Sub
End If
Then create a Text file named "Endless Loop Safety file.txt inside a temp folder placed onto the C drive. Now when ever that loop enters an endless state, you can rename the file to break the loop without crashing the software and losing work.
Credit:
In agreement with many here, tons of things go years without being addressed when it comes to the "Ideas" thread. Some pretty basic stuff that could be improved or implemented without notice.
Creating an add in and creating you own command definition would be possibly the easier way, since you can than cancel the command.
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
@J_Pfeifer_ wrote:
Going to pass on some amazing knowledge I was given awhile back...
Credit:
@J_Pfeifer_, To be fair, I "swiped" that code, likely from this forum... or somewhere else online... and then just incorporated it into some of my work. And then and just passed it along when I saw there was a need for it in your work.
I wish I was better at remembering who/where I get pieces like that from... but in any case a big thank you to everyone that contributes gems like that to this forum!
Inventor Forum links: Inventor iLogic , API and Customization Forum | Inventor Ideas Forum | General Inventor Forum
The other one I use sometimes, but is also not the most convenient, is the ProgressBar (when the Cancel button is allowed upon creation) and its ProgressBar.OnCancel Event , which is a tool that already exist in the Inventor API. There is an 'API Sample', but that sample is not include showing the cancel button, or handling the OnCancel event.
Years ago, although I had used it for some situations on occasion, I was skeptical about using it for situations where I may need to escape an endless loop type scenario, because I did not understand that much about 'threads / multi-thread processing' (and am still not an 'expert' in that area'), and I know that the ProgressBar was part of Inventor, and that Inventor may be frozen up at the time. But later, I heard from a couple people including @JelteDeJong(in his Blog post) that, when set-up properly, it actually works on a different thread than the loop is running on, so it was a viable candidate for that type of use. So, I often find myself incorporating that into my code solutions where a code could take a long time to run. I do generally try to avoid using Do...Loop, While...End While, and similar types loops, when possible, but have found a few places where they seem to be the better option, and in those cases, I may incorporate this also.
It is somewhat advanced though, because it does involve multi-sectional code layout, and the creation and use of EventHandler(s) to monitor some of Inventor's Events (not the iLogic Event Triggers), which most beginners do not understand much about yet, so maybe not a one size fits all type 'workaround'.
A had also heard about multiple similar ideas to the text file thing, where you would have a line of code within your loop that checks for something outside of Inventor's scope, but did not like the idea, due to most of my stuff being used by several other folks sometimes, and not having any control over things like that on other peoples computers.
All these types of ideas all seem to come down to the same basics though...having the forethought to either avoid creating a loop that may end up being endless in the first place, or having the forethought to include something special like one of these ideas within the loop as you create it.
Wesley Crihfield
(Not an Autodesk Employee)
