Announcements
How to specify file path as project file path?
heesu.kim96WY9
heesu.kim96WY9
hello.
Please understand that my English is not proficient.
Const sXLDoc As String = "C:Temp\BOM.xlsx"
Here, we want to specify the "Temp" path as the path where the project file is located. We need your help.
Dev_rim
You can get the Project file path like this:
    Dim oDesignProjectMgr As DesignProjectManager = inventorApplication.DesignProjectManager
    Dim ipjFilePath as String = oDesignProjectMgr.ActiveDesignProject.FullFileName
    Dim ipjFolderPath as String = System.IO.Path.GetDirectoryName(ipjFilePath)
    Dim sXLDoc As String = ipjFolderPath & "\BOM.xlsx"
You should use your inventor application object at line 1 for "inventorApplication". If you are using VBA its "ThisApplication".
 "ipjFolderPath" is the path that you need.
I recommend you check if the file already exists in desired location, before save the file. If there is a file with same name it will be an error. You can check it manually also. But you want to check it programmitically here is the code:
    If System.IO.File.Exists(sXLDoc) Then
        'The file exists Do something else
    Else
        'the file doesn't exist So you are safe
I hope this will solve your problem.
Devrim
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
heesu.kim96WY9
thank you.
Thanks for your help, problem solved.
