How to scale rectangular detail views
gabriele.tittonel
gabriele.tittonel
I have a rule to scale (rounded) detail views and I was wondering how adapt this rule for rectangular shaped detail views.
To scale the detail view, I have to scale first the fence radius, which I do this way:
' To access the fence radius, we need to use the "Item(i)" method:
' my case, the detail view Is the third one, and the label Is "B".
Dim oDetail As DetailDrawingView
    oDetail = ThisDrawing.Document.ActiveSheet.DrawingViews.Item(3)
    oDetail.FenceRadius = ActiveSheet.View("A").Width * 0.1
I guess there's a similar property to control the dimension of the detail, but so far, I haven't found it.
I've tried both: oDetail.Width and oDetail.Height but they are "read only" and so...
Any idea?
Andrii_Humeniuk
Hi @gabriele.tittonel . To control the fence of a rectangular DetailView, you need to get the properties: FenceCenterFenceCornerOneFenceCornerTwo.
An example of obtaining functions:
Dim oInvApp As Inventor.Application = ThisApplication
Dim oView As DrawingView
Do
	oView = oInvApp.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select View...")
	If oView Is Nothing Then Exit Sub
Loop While oView.ViewType <> 10502
Dim oDView As DetailDrawingView = oView
Try : Dim dR As Double = oDView.FenceRadius : Catch
	Dim oCPoint As Point2d = oDView.FenceCenter
	Dim oPoint1 As Point2d = oDView.FenceCornerOne
	Dim oPoint2 As Point2d = oDView.FenceCornerTwo
End Try
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Curtis_Waguespack
@gabriele.tittonel, I'm a little unclear as to what you're doing , but I'm thinking you will need to use some combination of these properties
DetailDrawingView.FenceCornerOne
DetailDrawingView.FenceCornerTwo
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-DetailDrawingView
Hope that helps.
But to just scale a rectangular detail view you can do something like this:
Dim oSheet = ThisDrawing.ActiveSheet
'parent view
Dim oView = oSheet.DrawingViews.ItemByName("VIEW1")
'detail view
Dim iDetailView = oSheet.DrawingViews.ItemByName("B")
'get the Inventor API object from the iLogic object
Dim oDetail As DetailDrawingView = iDetailView.View
If oDetail.CircularFence = False Then sType = "Rectangular"
'set the view scale to be 2x the parent view
oDetail.Scale = oView.Scale * 2
MsgBox(sType & " Detail is 2x it's parent view",, "iLogic")
'scale again by 10%
oDetail.Scale  = oDetail.Scale *1.1
MsgBox(sType & " Detail is scale " & oDetail.ScaleString ,, "iLogic")
gabriele.tittonel
@Curtis_Waguespack : Yes, it looks exactly what I need!
Also, interesting the "ItemByName" approach! 😀
