- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Forum
I have this line of code which saves my configurable part with a custom filename.
It works as intended.
Problem is I would like this file to be checked into the vault instead of saved in file explorer.
Can anyone help me change the code so the part is also checked into the vault.
Dim currentfilename As String Dim choice As String Dim length As String currentfilename = ThisDoc.FileName(False) choice = Parameter("FixedUnit_Curve") length = Parameter("FixedUnit_Length") 'custom filepath 'SetTheFilePathHere = "C:\ ... your filepath ..." 'filepath same as the current ipt SetTheFilePathHere = ThisDoc.Path SetTheFilenameHere = currentfilename & " - " & choice & " - L" & length & "mm" ThisApplication.CommandManager.PostPrivateEvent(kFileNameEvent, SetTheFilePathHere &"\" & SetTheFilenameHere & ".ipt") Dim oCtrlDef oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppFileSaveCopyAsCmd") oCtrlDef.Execute
Thank you for helping.
BR
Justin
