How to get parameters and mass of a part with Python
21 REPLIES 21
Message 1 of 22
14457 Views, 21 Replies
Hi all,
I am trying to get the list of parameters and mass properties from a .ipt, but it´s not working. Retrieving description and designer from the iproperties is in contrast no problem.
I´m a mechanical engineer and I´m using Python because it´s the only programming language I know.
This is my code:
import win32com.client
from win32com.client import gencache
oApp = win32com.client.Dispatch('Inventor.Application')
oApp.Visible = True
mod = gencache.EnsureModule('{D98A091D-3A0F-4C3E-B36E-61F62068D488}', 0, 1, 0)
oApp = mod.Application(oApp)
oApp.SilentOperation = True
oDoc = oApp.ActiveDocument
prop = oApp.ActiveDocument.PropertySets.Item("Design Tracking Properties")
# getting description and designer from iproperties (works)
Descrip = prop('Description').Value
Designer = prop('Designer').Value
print(Descrip)
print(Designer)
# getting mass and parameters (doesn´t work)
MassProps = oDoc.ComponentDefinition.MassProperties
partDef = oDoc.ComponentDefinition.Parameters
and this is the error message I get:
File "M:/Python/Idas_Arbeit/inventor_7.py", line 21, in <module>
    oMassProps = oDoc.ComponentDefinitions.MassProperties
  File "M:\zzz_Anaconda\lib\site-packages\win32com\client\__init__.py", line 473, in __getattr__
    raise AttributeError("'%s' object has no attribute '%s'" % (repr(self), attr))
AttributeError: '<win32com.gen_py.Autodesk Inventor Object Library.Document instance at 0x2937542647032>' object has no attribute 'ComponentDefinitions'
I use Inventor 2018 and Python 3.6.2. on Windows 10.
Any ideas? Your help would be very much appreciated!
21 REPLIES 21
Message 2 of 22
bradeneuropeArthur
For the massprop you need to do the following:
MassProps = oDoc.ComponentDefinition.MassProperties.mass
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Message 3 of 22
bradeneuropeArthur
Hoi need another declaration
Make the declaration to PartComponentDefinition for parts.
Make the declaration to assemblyComponentDefinition for assemblies.
This should do it!
Arthur Knoors
Message 4 of 22
in reply to: bradeneuropeArthur
Hi bradeneurope,
thanks for your support. Unfortunately this does not help, I still get the same error: ...object has no attribute 'ComponentDefinition'
Message 5 of 22
how do I do this:
"Make the declaration to PartComponentDefinition for parts.
Make the declaration to assemblyComponentDefinition for assemblies."
Could you please provide the Python code for it?
Message 6 of 22
bradeneuropeArthur
Take a look at this:
You need to declare your component definitions as first as part and assembly.
Dim bA As AssemblyDocument
Set bA = a.ActiveDocument
Dim cA As AssemblyComponentDefinition Set cA = bA.ComponentDefinition Dim dA As MassProperties Set dA = cA.MassProperties
Dim bP As PartDocument
Set bP = a.ActiveDocument
Dim cP As PartComponentDefinition
Set cP = bP.ComponentDefinition
Dim dP As MassProperties
Set dP = cP.MassProperties
So do not use:
.. oDoc.ComponentDefinitions.Massproperties
Arthur Knoors
Message 7 of 22
"""declaration"""
oPartDoc = PartDocument()
oPropset = PropertySets()
oPartCompdef = PartComponentDefinition()
MassProp = MassProperties()
MassofPart = Double()
oDescrip = Property()
oDesigner = Property()
oParams = Parameters()
oModelParams = ModelParameters()
oModelParam_1 = ModelParameter()
"""Set the Object"""
oPartDoc = ThisApplication.ActiveDocument
PropertySets = opartdoc.PropertySets.item('Design Tracking Properties')
oDescrip = propertysets.item('Description')
oDesigner = propertysets.item('Designer ')
oPartCompdef = oPartDoc.ComponentDefinition
MassProp = oPartCompdef.MassProperties
MassofPart = MassProps.Mass
oParams = oPartCompDef.Parameters
oModelParams = oParams.ModelParameters
oModelParam_1 = oModelParams.Item(1)
"""Get the Data"""
print(oDescrip.value)
print(oDesigner.value)
print(massofpart)
print(oModelParam_1.Value + ' cm')
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 8 of 22
in reply to: dgreatice
Hi dgreatice,
thank you for your idea!
Unfortunately it is not working yet. I get the following error: NameError: name 'PartDocument' is not defined.
I think the declaration you did is necessary, but somehow Python is expecting it in a different way?!
Message 9 of 22
dgreatice
are python can add reference library?
at Visual Studio, I need to add reference library to read class of API Inventor. Like:
C:\Program Files\Autodesk\Inventor 2014\Bin\Public Assemblies\Autodesk.Inventor.Interop.dll
Message 10 of 22
bradeneuropeArthur
Take a look at my last post. This should solved it Maybe.
Arthur Knoors
Message 11 of 22
Hi dgreatice,
adding the library sounds like the right thing to do. I found out that the module for this is called "ctypes" in Python, however I didn´t manage to install and use it properly so far.
I keep trying ...
Message 12 of 22
dgreatice
hi,
try to find any clue from youtube.
https://www.youtube.com/watch?v=VHxqGJc8hsM&t=62s
Message 13 of 22
I find myself in the same situation, I only know Python and I have a few scripts that used ComponentDefinition method. They used to work well, on Inventor 2015, but since the company updated to Inventor 2015 SP2 Update 6, a few days ago, my scripts stopped functioning. Autodesk must have modified something in their COM code... Have you found any solution for your problem yet?
Best regards,
Liviu
Message 14 of 22
chandra.shekar.g
Hi @Anonymous,
Try the following python code to retrieve mass properties
from win32com.client import gencache, Dispatch, constants, DispatchEx
oApp.Visible = True
# oApp.SilentOperation = True
oDoc = mod.PartDocument(oDoc)
print(Descrip)
print(Designer)
dArea = MassProps.Area
print(dArea)
lNum = partDef.Count
print(lNum)
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 15 of 22
in reply to: chandra.shekar.g
Hi chandra.shekar.g,
I tried your solution, but I got stuck at:
Traceback (most recent call last):
  File "<interactive input>", line 1, in <module>
TypeError: 'module' object is not callable
I am using Pyhton 2.7.3 32bit on win32 in a PyScriper console.
What I find curious is that I have another application written in Python, which uses ComponentDefinition.Parameters, which I 'froze' with py2exe. That one still works fine, but if I copy the source code in the Python interpreter, I get the error posted by our friend ma23UNC:
It is such a pity, I really enjoyed automating Inventor in Python....
Thank you,
Liviu
Message 16 of 22
bradeneuropeArthur
try this
import win64com.client
from win64com.client import gencache, Dispatch, constants, DispatchEx
oApp = win64com.client.Dispatch('Inventor.Application')
oApp.Visible = True
print(Descrip)
print(Designer)
print(dArea)
print(lNum)
Arthur Knoors
Message 17 of 22
Remarks:
Please put your Software versions in your heading so we can see the software version you use.
Arthur Knoors
Message 18 of 22
To the best of my knowledge, 'win64com' does not exist (yet?)....
Message 19 of 22
bradeneuropeArthur
Does this work then:
oApp = win32com.client.Dispatch("Inventor.Application")
oApp.Visible = True
mod = gencache.EnsureModule("{D98A091D-3A0F-4C3E-B36E-61F62068D488}", 0, 1, 0)
Descrip = prop("Description").Value
Designer = prop("Designer").Value
print(Descrip)
print(Designer)
print(dArea)
print(lNum)
I have used "######" instead of '######'
Arthur Knoors
Message 20 of 22
No, it still does not work. Does it work for you?
*** Python 2.7.3 (default, Apr 10 2012, 23:31:26) [MSC v.1500 32 bit (Intel)] on win32. *** *** Remote Python engine is active *** >>> import win32com.client >>> win32com.client <module 'win32com.client' from 'C:\Users\________\Documents\PORTABLE PROGRAM FILES\Portable Python 2.7.3.1\App\lib\site-packages\win32com\client\__init__.pyc'> >>> from win32com.client import gencache, Dispatch, constants, DispatchEx >>> oApp = win32com.client.Dispatch("Inventor.Application") >>> oApp <win32com.gen_py.Autodesk Inventor Object Library.Application instance at 0x45696624> >>> oApp.Visible = True >>> mod = gencache.EnsureModule("{D98A091D-3A0F-4C3E-B36E-61F62068D488}", 0, 1, 0) >>> mod <module 'win32com.gen_py.D98A091D-3A0F-4C3E-B36E-61F62068D488x0x1x0' from 'C:\Users\______\AppData\Local\Temp\gen_py\2.7\D98A091D-3A0F-4C3E-B36E-61F62068D488x0x1x0\__init__.pyc'> >>> oApp = mod.Application(oApp) Traceback (most recent call last): File "<interactive input>", line 1, in <module> TypeError: 'module' object is not callable
Inventor 2015
64-Bit Edition
Build 223, Release 2015 SP2 Update 6
Windows 7 Entreprise SP1
