After reading this post i realised there is a better way to do this.
Dim doc As PartDocument = ThisDoc.Document
Dim def As SheetMetalComponentDefinition = doc.ComponentDefinition
If (def.HasFlatPattern) Then
def.FlatPattern.Edit()
Else
def.Unfold()
End If
Dim flat As FlatPattern = def.FlatPattern
Dim edgeloops As EdgeLoops = flat.TopFace.EdgeLoops
Dim oMeasure As MeasureTools = ThisApplication.MeasureTools
Dim outerPerimeter As Double = 0
Dim breakthroughsPerimeter As Double = 0
For Each edgeLoop As EdgeLoop In edgeloops
' length is multiplied by 10 to convert cm to mm
Dim edgeLength = oMeasure.GetLoopLength(EdgeLoop) * 10
If (EdgeLoop.IsOuterEdgeLoop) Then
outerPerimeter = outerPerimeter + edgeLength
Else
breakthroughsPerimeter = breakthroughsPerimeter + edgeLength
End If
Next
flat.ExitEdit()
MsgBox("Number of bends: " & def.Bends.Count & System.Environment.NewLine &
"Number of edge loops (that includes outerprofile): " & edgeloops.Count & System.Environment.NewLine &
"Number of breakthroughs: " & (edgeloops.Count - 1) & System.Environment.NewLine &
"Total outer perimeter: " & Math.Round(outerPerimeter, 1) & System.Environment.NewLine &
"Total breakthroughs perimeter: " & Math.Round(breakthroughsPerimeter, 2))
Jelte de Jong
Blog: hjalte.nl - github.com
