How to enable “Accept successful blends” using .NET API
pdsa
pdsa
Hi
I’m using the Fillet Feature to add All Fillets on a part but when it fails I can’t make it work as in the UI where it’s possible to “Accept successful blends” in the API (.NET) see attached picture
Is this missing from the API? Any workaround or code to find all "all Fillets" edges is much appreciated.
Kind regards
Patrick de Stobbeleir
chandra.shekar.g
Autodesk Support
Autodesk Support
@pdsa,
Unfortunately, Inventor API does not support "Accept successful blends". Currently, no workaround for this to achieve.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
