How to drive constraints
martinhoos
martinhoos
Hello together,
i need your your help. I like to drive, move and rotate constraints with ilogic. The following code rotates all of the driven constraints. The code shouldt be drive only a constraint named "move1" vertical from 0 to 155 and rotated an other constraint named "rotate1" from 0 to 45 degree. Is that possible?
And another question: The code rotates clockwise from 0 to 45 degree. Is it possible to rotate from 0 to -45?
Thanks in advance
Regards Martin
Sub Main()
    Dim assyDoc As AssemblyDocument
    assyDoc = ThisApplication.ActiveDocument
    Dim oConstraint As AssemblyConstraint
    For Each oConstraint In assyDoc.ComponentDefinition.Constraints
        If oConstraint.DriveConstraintSettings.IsInitialized Then
            With oConstraint.DriveConstraintSettings
				.StartValue = 0
                .EndValue = 45
                .GoToStart
                .PlayForward
'                .StartValue = 0
'                .EndValue = 150
'                .GoToEnd
'                .PlayReverse
			End With
        End If
    Next
End Sub
chandra.shekar.g
Autodesk Support
Autodesk Support
@martinhoos,
Try below iLogic code to move and rotate to drive constraints.
Sub Main()
		If oConstraint.Name = "move1" Then
			.StartValue = "0"
	                .EndValue = "155"
	                .GoToStart
	                .PlayForward
				End With
        	End If
		ElseIf oConstraint.Name = "rotate1" Then
			.StartValue = 0
	                .EndValue = 45
	                .GoToStart
	                .PlayForward
				End With
        	End If
		End If
    Next
End Sub
Try 0 to 315 (360 - 45) to rotate from 0 to -45.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
martinhoos
Hello Chandra,
thank you very much for your help! Great work...
Regards Martin
miroslav.roydev
How i can drive multiple constraints ?
