How to disable Form Inputs in iLogic
Hello all,
I'm looking for a way to force a form to calculate an input based on a user selection.
See the images - easier to explain with pictures.
Hi @Anonymous!
to achieve that you could use a parameter (bool) and connect it with the Button/Dropdown or whatever.
Of course you could even control such a param by iLogic or VBA.
Find screenshots attachet of what I am trying to explain.
If this sounds good or you have any questioins, let m know :winking_face:
bradeneuropeArthur
I assume you mean disabling textboxes and buttons etc like you can do in Vb.net forms and VBA forms.
I think this is not possible for I-logic, but I am not sure!
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
