How to delete non-existing reference in Inventor DWG
psaarloos
psaarloos
I am having a problem with Inventor DWG files. After moving to Vault they seem to have a reference to a bitmap. I found an older posting in the Vault forums which highlights the issue.
https://forums.autodesk.com/t5/vault-general-discussion/fix-this-stupid-problem-reference-to-non-exi...
How can I remove this reference with the Inventor API? Using the AutoCAD API is not an option. Or is there any other fix possible?
Pim
Pim Saarloos
Product Manager
If my post answers your question, please click the "Accept as Solution" button. Kudos are much appreciated!
Replies (7)
KarelC
for this problem I use my inventor macro (seven years old). I tryed it only for idw. You can try it for dwg.
Sub Vymaz_ExtRef()
Dim oDoc As Inventor.Document
Dim ref As Inventor.ReferencedOLEFileDescriptor
Dim i As Integer
Dim names As String
'get external references:
Set oDoc = ThisApplication.ActiveDocument
names = ""
i = 1
For Each ref In oDoc.ReferencedOLEFileDescriptors
names = names & Chr(10) & Chr(13) & ref.DisplayName & " = " & ref.FullFileName
ref.Delete
i = i + 1
Next
MsgBox ("References:" & names)
End Sub
___________________________________________________________
Dell Precision T3620
Inventor 2019, Autocad Mechanical 2019, Vaul Basic 2019
psaarloos
Thanks for your reply. I looked at the ReferencedOLEFileDesscriptors, but the collection is empty. Still the reference is shown when I try to check in the file in to Vault. Because the file doesn't really exist it blocks me from checking in the file.
The weird thing is that the XRef Manager in AutoCAD is showing the bitmap as unreferenced and I can remove the reference there. Therefore I added a reference to the AutoCAD Type Library in Inventor VBA allowing me to set a reference to the ContainingDWGDocument property of the DrawingDocument. In the AcadDatabase however, I am unable to find the XRef.
Hope there it's possible to programmatically remove the reference, because I have a lot of drawing documents which needs to be checked in to Vault.
Pim Saarloos
Product Manager
Curtis_Waguespack
Hi psaarloos,
I'm not sure about using the API, but aan you use this break link tool as shown in this image?
I hope this helps.
Curtis
psaarloos
Thank you very much for your suggestion. Unfortunately the 'Links' command is disabled (probably because it can't find link). Another weird thing though; Design Assistent is complaining about the missing reference as well. As far as I know Design Assistent is using Inventor Apprentice, but can't find the reference to the bitmap in the ApprenticeServerDocument either...
Pim Saarloos
Product Manager
psaarloos
I've found a solution by adding a reference to the AutoCAD Type Library from within Inventor VBA and accessing the ContainingDWGDocument object. Hoipefully it help somebody else with the same issue.
Pim
Dim odoc As DrawingDocument
Set odoc = ThisApplication.ActiveDocument
Dim acad As AcadDatabase
Set acad = odoc.ContainingDWGDocument
Dim removed As Boolean
On Error Resume Next
Dim acadObj As Object
For Each acadObj In acad.Dictionaries
    If TypeOf acadObj Is AcadDictionary Then
            If acadObj.Name = "ACAD_IMAGE_DICT" Then
                Dim acadImageDict As AcadDictionary
                Set acadImageDict = acadObj
                acadImageDict.Remove "<imagename>"
                removed = True
                Exit For
            End If
    End If
Next
On Error GoTo 0
If removed Then
    odoc.Update2
    odoc.Save
    ThisApplication.CommandManager.ControlDefinitions("VaultRefresh").Execute
End If
Pim Saarloos
Product Manager
info
Try to open dwg in Autocad type xref command and detach missing link.
slmiller6Y5FH
Having the same issue. This worked.
