How to Create Workplane At UCS Origin?
NSBowser
NSBowser
Simplified Situation:
I have an assembly (assyDoc) which contains a UCS in 3D Space, not aligned relative to the origin at all. I would like to create a workplane, such as via AddByPlaneAndPoint, using an Assembly Origin Plane and the UCS Center Point.
What I've Tried:
I've tried using the UCS.origin, which returns a workpoint, but that errors:
var wp1 = workPlanes.AddByPlaneAndPoint(assyYZPlane, UCS.Origin);
I thought maybe the UCS origin and Center Point were not the same thing, so I tried creating a Pt using the 3 UCS planes first, but that also errors:
var centerPt = workPoints.AddByThreePlanes(UCS.XYPlane, UCS.XZPlane, UCS.YZPlane);
It feels to me like I'm missing a proxy aspect the way that it wont create work features in the assembly using the UCS items, however, you can only create proxies (as far as i am aware) using componentOccurrences, which the UCS in the assembly is not. Maybe there is something i am missing that the UCS planes are not really at the same level in the assembly as I am thinking they are, but I see no other way of utilizing them or creating proxies of them.
Thanks for any help!
Nathan
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
Frederick_Law
If I remember correctly, not all plane creation method works.  Some wrok in part and some work in assembly.  Also what need to be passed are pretty specific type.  This took some trial and error so it may not be to best solution.
This is what I use to create point and planes on COG, VS VB.net Inventor addin:
    Private Sub COGUpdate()
      Dim oWorkPoint As WorkPoint
      Dim oWorkPlane As WorkPlane
      Dim vX, vY, vZ As UnitVector
      Dim oFixedDef As FixedWorkPointDef
      Dim oAssPtDef As AssemblyWorkPointDef
      Dim PointExist As Boolean = False
      Dim COGXYExist As Boolean = False
      Dim COGXZExist As Boolean = False
      Dim COGYZExist As Boolean = False
      Dim oDoc As Document = m_inventorApplication.ActiveDocument
      Dim oCenterOfMass As Point = oDoc.ComponentDefinition.MassProperties.CenterOfMass
      For Each oWorkPoint In oDoc.ComponentDefinition.WorkPoints
        If oWorkPoint.Name = "COG" Then
          PointExist = True
          If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            oAssPtDef = oWorkPoint.Definition
            oAssPtDef.Point = oCenterOfMass
          ElseIf oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
            oFixedDef = oWorkPoint.Definition
            oFixedDef.Point = oCenterOfMass
          End If
          oDoc.Update()
          Exit For
        End If
      Next
      If Not PointExist Then
        oWorkPoint = oDoc.ComponentDefinition.WorkPoints.AddFixed(oCenterOfMass)
      End If
      vX = m_inventorApplication.TransientGeometry.CreateUnitVector(1, 0, 0)
      vY = m_inventorApplication.TransientGeometry.CreateUnitVector(0, 1, 0)
      vZ = m_inventorApplication.TransientGeometry.CreateUnitVector(0, 0, 1)
      For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes
        Select Case oWorkPlane.Name
          Case "COG XY"
            oWorkPlane.SetFixed(oWorkPoint.Point, vX, vY)
            COGXYExist = True
            'oWorkPlane.Delete()
          Case "COG XZ"
            oWorkPlane.SetFixed(oWorkPoint.Point, vX, vZ)
            COGXZExist = True
          Case "COG YZ"
            oWorkPlane.SetFixed(oWorkPoint.Point, vY, vZ)
            COGYZExist = True
          Case Else
            Exit Select
        End Select
      Next
      If Not COGXYExist Then
        oWorkPlane = oDoc.ComponentDefinition.WorkPlanes.AddFixed(oWorkPoint.Point, vX, vY)
        oWorkPlane.Name = "COG XY"
      End If
        oWorkPlane = oDoc.ComponentDefinition.WorkPlanes.AddFixed(oWorkPoint.Point, vX, vZ)
        oWorkPlane.Name = "COG XZ"
      End If
      If Not COGYZExist Then
        oWorkPlane = oDoc.ComponentDefinition.WorkPlanes.AddFixed(oWorkPoint.Point, vY, vZ)
        oWorkPlane.Name = "COG YZ"
      End If
      oDoc.Update()
    End Sub
NSBowser
Thanks, I see now that MOST work plane (and other work feature) creation methods do not work in an assembly. Since we are pretty much left with fixed, I ended up using your approach. Here's the portions that worked for me.
Thanks Again!
 UnitVector xUV = transGeo.CreateUnitVector(1, 0, 0);
 UnitVector yUV = transGeo.CreateUnitVector(0, 1, 0);
 UnitVector zUV = transGeo.CreateUnitVector(0, 0, 1);
xPlane = workPlanes.AddFixed(centerPt.Point, yUV, zUV);
zPlane = workPlanes.AddFixed(centerPt.Point, xUV, yUV);
Best of Luck
