How to create cosmetic bend centerlines with the API
HermJan.Otterman
HermJan.Otterman
Does any one know if it is possible to create cosmetic centerlines in a flatpattern with the Inventor API??
eventualy I create a drawing of my flatpattern and export my Flatpattern to an Autocad dwg. for this I use the export option "Model Geometry only", because of this, any sketches made on the drawing are gone... so I want to make them in the flatpattern with the Cosmetic centerlines because them come on my drawing with the export..
thanks
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
HermJan.Otterman
Can someone from Autodesk maybe reply??
is it possible to create a cosmetic bendline in a flatpattern with the API
I tried it with the commandmanager, but then my selection is gone, as soon as I execute it.
alsoI have to press OK...? can that be done?
Herm Jan
chandra.shekar.g
Autodesk Support
Autodesk Support
@HermJan.Otterman,
Is it possible through UI? If yes, can you please provide steps to create cosmetic bend centerlines via UI?
For more understanding, video record or screencast would be better.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Thanks for useful link.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
chandra.shekar.g
Autodesk Support
Autodesk Support
@HermJan.Otterman and @GeorgK,
I checked with engineering team and informed that Inventor API does not support to cosmetic bend lines currently. Please log this wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
HermJan.Otterman
Thanks guys,
I will make a wish and in the mean time look for and other workflow.
Herm Jan
