Hi @ikilic1461. Here is some iLogic code you can use as a 'local' rule in that document. If the parameter's name is "A2", then when you use that unquoted name within a 'local' rule, it will trigger that rule to run any time the value of that parameter changes. Then this rule should effectively & automatically keep the value of that parameter within the range specified. However, keep in mind that raw numbers in iLogic that represent measurements, will automatically be understood by Inventor as 'database' units (metric base units >>> length = centimeters, angle = radians, mass = grams, etc.) So you may have to play with the numbers within the rule to get the 'units' to work out as you need them to.
Here's the iLogic rule code:
If A2 < 200 Then
MsgBox("A2 must be within 200 to 500." & vbCrLf & _
"Lower values will be set to 200.",vbInformation,"Parameter Police")
A2 = 200
ElseIf A2 > 500 Then
"Higher values will be set to 500.",vbInformation,"Parameter Police")
A2 = 500
End If
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS)
If you want and have time, I would appreciate your Vote(s) for My IDEAS
or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
