How to Check if Inventor is in Darkmode?
bradeneuropeArthur
bradeneuropeArthur
How to Check if Inventor is in Darkmode via the API?
Arthur Knoors
Autodesk Affiliations:
Ralf_Krieg
Hello
Not sure, but isn't dark mode not only a color scheme named "dark"? So if the ThisAplliatiocn.ActiveColorScheme.Name="Dark" then dark mode?
R. Krieg
RKW Solutions
www.rkw-solutions.com
bradeneuropeArthur
Found:
thisapplication.ThemeManager.ActiveTheme.Name
Arthur Knoors
