Announcements
How to Change Visibility of body in a part file using ilogic
I have a part file with 7 bodies. How do i make one body invisible using ilogic rule.
I need to make make the body "FEA house " and then export the file seperately.
Regards,Neil
Sergio.D.Suárez
Hi, this is a method to access each body of the multibody part file. You access through the item.
Dim oDoc As PartDocument = ThisDoc.Document
Dim oCD As ComponentDefinition = oDoc.ComponentDefinition
Dim oSolid As SurfaceBody = oCD.SurfaceBodies.Item(3)
oSolid.Visible = False
  If you have your bodies correctly named in your tree inside the browser, you could also hide through the name. You should create a loop that searches between all surfacebodies and when it finds a solid with the same name as you choose, then hide this solid.
I hope this helps with your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
