How to change Model State of view in Drawing Document?
W.Scott.Dempster
W.Scott.Dempster
I have a Part Document with various Model States. I have a macro which I would like to have change the active model state in its Drawing Document. Here is a snippet of code I am using. On the DV.ActiveModelState line, I am getting an error stating incorrect number of arguments of an invalid property assignment. Is there something wrong with this?
Sub ChangeModelState()
    Dim PN As String
    PN = "999998"
    Dim app As Application
    Dim IDW As DrawingDocument
    Set app = ThisApplication
    Set IDW = app.ActiveDocument
    Dim DV As DrawingView
    Set DV = IDW.ActiveSheet.DrawingViews(1)
    Dim DVfp As DrawingView 'Flat pattern
    Dim view As DrawingView
    Dim oPart As PartDocument
    Set oPart = IDW.ReferencedDocuments.Item(1)
    Dim oModelState As ModelState
    Set oModelState = oPart.ComponentDefinition.ModelStates
    For Each view In IDW.ActiveSheet.DrawingViews
        If view.IsFlatPatternView = True Then
            Set DVfp = view
    Next view
    Dim fileName As String
    Dim i As Long
    Dim memberName As String
    memberName = "[Primary]"
    DV.ActiveModelState = memberName
    DVfp.ActiveModelState = memberName
End Sub
WCrihfield
Hi @W.Scott.DempsterDrawingView.ActiveModelState is a ReadOnly Property.  To set its value, you need to use the DrawingView.SetActiveModelState method.
Wesley Crihfield
(Not an Autodesk Employee)
W.Scott.Dempster
Thank you.
