How to change item number in BOM via API
Hi All,
some info on how to:
Change Item Number in BOM
Thanks, best regards
Massimo
MechMachineMan
"Find No.".
Is that a Custom iProperty that is stored within your documents, or are you referring to item number?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Hi is about the Item Number.
Thanks, regards
Massimo
MechMachineMan
Are you wanting to change the item number of just one part?
Are you wanting to renumber all of the parts?
Are you planning on changing it based off of something else?
When you get access to the BOMView object, it is pretty straight forward to grab item numbers.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-3889FFBD-C3A1-472A-BBF3-E69563008E10
Justin K
