How to categorize user created parameters
Thomas.Long
Thomas.Long
So I find myself with large assemblies again and I have a plethora of user parameters (some of them are just for the purpose of being able to view the program for watching for errors) and I'm trying to categorize these parameters in order to make it much more manageable. However all there seems to be is the built in filters, but what would really be helpful would be the ability to create subcategories, like folders, to organize them by.
Is this at all possible?
HermJan.Otterman
Hello Thomas,
Look in the API help for: Custom Parameter Groups, and you will find this code:
it might help you. (This is API only!)
Public Sub CreateParametersAndGroup()
    ' Create a new Part document.
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
                 ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
    ' Set a reference to the compdef.
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oPartDoc.ComponentDefinition
    ' Create a model parameter
    Dim oModelParam As ModelParameter
    Set oModelParam = oCompDef.Parameters.ModelParameters.AddByValue(2, kCentimeterLengthUnits)
    ' Create a reference parameter
    Dim oReferenceParam As ReferenceParameter
    Set oReferenceParam = oCompDef.Parameters.ReferenceParameters.AddByValue(4, kCentimeterLengthUnits)
    ' Create a user parameter
    Dim oUserParam As UserParameter
    Set oUserParam = oCompDef.Parameters.UserParameters.AddByValue("length", 6, kCentimeterLengthUnits)
    ' Create a new custom parameter group
    Dim oCustomParamGroup As CustomParameterGroup
    Set oCustomParamGroup = oCompDef.Parameters.CustomParameterGroups.Add("Custom Group", "CustomGroup1")
    ' Add the created parameters to this group
    ' Note that adding the parameters to the custom group
    ' does not remove it from the original group.
    Call oCustomParamGroup.Add(oModelParam)
    Call oCustomParamGroup.Add(oReferenceParam)
    Call oCustomParamGroup.Add(oUserParam)
End Sub
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Thomas.Long
It looks a little over my head but I think I get it. I generally run these as not visual basic and this is running in an assembly. It looks like the rule shown was meant for a part document so I changed a little bit.
I ran it originally as straight vb and it didn't actually create anything that I could see so I tried modifying it a bit. This was a little test I ran to see if I could adapt it to accept pre existing Parameters, which sadly didn't work. Gave me the error "Object of type 'System.UInt32' cannot be converted to type 'Inventor.CommandTypesEnum'."
I've seen it before but that error seems to show up for a multitude of reasons. I did check the help area and while it mentions that you can create special parameter folders it doesn't say how oddly enough.
Thank you again
Sub Main()
	Dim oAsmDoc as AssemblyDocument = ThisDoc.Document
	Dim oAsmCompDef As ComponentDefinition
	oAsmCompDef = oAsmDoc.ComponentDefinition
    oCustomParamGroup = oAsmCompDef.Parameters.CustomParameterGroups.Add("Custom Group", "Rafters")
    oCustomParamGroup.Add("Rafters")
End Sub
Thomas.Long
Apologies, I made a bit of a mistake in that code though I'm still getting the same error. Here is the updated code.
Sub Main()
    oUserParam = ParaExist("Rafters")
End Sub
'The ParaExist function returns the parameter with the name passed to it.
Function ParaExist(sName)
	Dim oDoc As AssemblyDocument
	oDoc = ThisDoc.Document
	Dim oCompDef As AssemblyComponentDefinition
	oCompDef = oDoc.ComponentDefinition
	For i = 1 To oCompDef.Parameters.Count
		If oCompDef.Parameters(i).Name = sName
			ParaExist = oCompDef.Parameter(i)
			Exit For
		End If
	Next
End Function
HermJan.Otterman
try this:
 Sub Main()
Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
Dim oAsmCompDef As AssemblyComponentDefinition = Nothing
Dim oCustomParamGroup As CustomParameterGroup = Nothing
Try
oCustomParamGroup = oAsmCompDef.Parameters.CustomParameterGroups.Add("Category name", "Category name")
Catch ex As Exception
'it probably already exists
oCustomParamGroup = oAsmCompDef.Parameters.CustomParameterGroups("Category name")
End Try
'enter existing parameter name, and copy the line for more parameters
Dim oExistingParam As Inventor.Parameter = GetExistingParam(oAsmDoc, "Length")
'add parameter
oCustomParamGroup.Add(oExistingParam)
Dim oExistingParam1 As Inventor.Parameter = GetExistingParam(oAsmDoc, "Width")
'add parameter
oCustomParamGroup.Add(oExistingParam1)
 End Sub
Private Function GetExistingParam(ByVal oAssydoc As Inventor.AssemblyDocument, oParamName As String) As Inventor.Parameter
Dim oParam As Inventor.Parameter = Nothing
For Each oParam In oAssydoc.ComponentDefinition.Parameters
If oParam.Name = oParamName Then
Return oParam
End If
Next
Return Nothing
End Function
put it all in one iLogic rule
Herm Jan
Thomas.Long
Thank you! That does precisely what I wanted. I was a tad confused when I first tried it because it was still giving the error, but I realized it didn't have a catch for if it didn't find the parameter. If it didn't find it the function had a catch to just return nothing but then it tried to add nothing to the category. I may set up a catch later but for now the function works precisely as I wanted, thank you so much.
