how to allow custom values
marcin_bargiel
marcin_bargiel
How to set by iLogic or VB :  "allow custom values" for all user multivalue parameters? (when creating them or later)
Vote for REPLACE VARIES !
REPLACE VARIES
Replies (10)
HermJan.Otterman
Hello Marcin,
The parameter has an attribute
UserParameters.item(1).attributeSets.item("com.autodesk.inventor.parameterAttributes").item("AllowCustomValue").value = 0/1
this should help you, I hope
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
marcin_bargiel
Hello
Thank's but it seems that it works, but only if i first manually set "allow custom value",
without setting at beginning i got failure (i quess that item AllowCustomValue not exist !)
then by this code i can only change seeting from 0 or 1
REPLACE VARIES
HermJan.Otterman
as soon as you make a multi value parameter, the attribute will also be created for that parameter.
value = 0  : check is off
value = 1   : check is on
when a parameter is not a multi value parameter the attribute does not exist
Herm Jan
marcin_bargiel
could You please look my file? inv. 2020.2
i disagree with You, attribute is not created, but true is that it should be created :slightly_smiling_face:
REPLACE VARIES
HermJan.Otterman
Hello Marcin,
apperently the attribute is not created if you make the multyvalue by code....
so I altered your iLogic code a little so that the attribute is created.
the condition still is there that it should be a multi value!
try it, and let me know
Herm Jan
marcin_bargiel
Great job, thank's a lot !
REPLACE VARIES
marcin_bargiel
One line must be added, if not, it worked only after manualy open list of parameters
pcd.Parameters.UserParameters.Item("param_N").AttributeSets.Add("com.autodesk.inventor.ParameterAttributes")
REPLACE VARIES
b.vonklass
Dear Marcin,
exactly the functionality described here would help me a lot. Unfortunately, I am not getting the rule to run smoothly. I guess it has to do with the fact that I am creating the MultiValueList Parameters with an ilogic rule and therefore the AttributeSet does not seem to be created with it. Is it possible to post the complete rule text here again. That would be great. Thanks a los.
Best regards Ben
marcin_bargiel
Sub Main
	Add_Parameters
End Sub
Sub Add_Parameters
Dim doc As PartDocument
doc = ThisDoc.Document
Dim pcd As PartComponentDefinition
pcd = doc.ComponentDefinition
If ThisApplication.ActiveDocumentType = kPartDocumentObject Then
MultiValue.UpdateAfterChange = True
MultiValue.SetValueOptions(True)
'example to only setmulivalue
j = 10
For i = 1 To j : Try : If Parameter("k_flange_N" & i) <> -100 Then : End If : Catch : doc.ComponentDefinition.Parameters.UserParameters.AddByExpression("k_flange_N" & i, 1, "mm")  : End Try : Next
For i = 1 To j : MultiValue.SetList("k_flange_N" & i, -1, 0, 1) : Next
'example to setmulivalue and allow custom value
j = 20
index_no = 2
For i = 1 To j : Try : If Parameter("set_N" & i) <> -100 Then : End If : Catch : doc.ComponentDefinition.Parameters.UserParameters.AddByExpression("set_N" & i, 0, "mm")  : End Try : Next
For i = 1 To j
	MultiValue.SetList("set_N" & i, -2, -1, 0, 1)
	Set_Attributes_To_Mulitivalue("set_N" & i)
	'set default index value
	Dim oParam1 As UserParameter
	oParam1 = ThisDoc.Document.componentdefinition.parameters.item("set_N" & i)
	oParam1.ExpressionList.SetExpressionList(oParam1.ExpressionList.GetExpressionList(), True, index_no)
Next
RuleParametersOutput()
InventorVb.DocumentUpdate()
End If
End Sub
Function Set_Attributes_To_Mulitivalue(PARAM_NAME As String)
	Try
        Dim paramAttribSet As AttributeSet
		pcd.Parameters.UserParameters.Item(PARAM_NAME).AttributeSets.Add("com.autodesk.inventor.ParameterAttributes")
        paramAttribSet = pcd.Parameters.UserParameters.Item(PARAM_NAME).AttributeSets.Item("com.autodesk.inventor.ParameterAttributes")
        Try
            paramAttribSet.Add("AllowCustomValue", ValueTypeEnum.kIntegerType, 0)
        Catch ex As Exception
        End Try
        paramAttribSet.Item("AllowCustomValue").Value = 1
	Catch
	End Try
End Function
REPLACE VARIES
b.vonklass
Thanks a lot :grinning_face:! Exactly what I was looking for. Works great!
