How to Add assembly mate constraint _API
I try to assembly mate constraint on these two-part with a limit angle between those part.
1) How can I set a mate on those tubes?
2) How to make a limit angle between those bodies?
Could anybody show some examples? Thank you!
Any help would be much appreciated!
bradeneuropeArthur
give this a try:
Public Sub MateConstraint()
    ' Set a reference to the assembly component definintion.
    Dim oAsmCompDef As AssemblyComponentDefinition
    Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    ' Set a reference to the select set.
    Dim oSelectSet As SelectSet
    Set oSelectSet = ThisApplication.ActiveDocument.SelectSet
    ' Validate the correct data is in the select set.
    If oSelectSet.Count <> 2 Then
        MsgBox "You must select the two entities valid for mate."
        Exit Sub
    End If
    ' Get the two entities from the select set.
    Dim oBrepEnt1 As Object
    Dim oBrepEnt2 As Object
    Set oBrepEnt1 = oSelectSet.Item(1)
    Set oBrepEnt2 = oSelectSet.Item(2)
    ' Create the insert constraint between the parts.
    Dim oMate As MateConstraint
    Set oMate = oAsmCompDef.Constraints.AddMateConstraint(oBrepEnt1, oBrepEnt2, 0)
End Sub
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
