How to add a WPF window to an Add-In
piotrekdoro94
piotrekdoro94
Hi, I'm trying to convert my plugins to proper add-ins with limited success. I have problems trying to add a WPF window as a UI and attaching some code to it.
For example: I have a simple code snippet that creates a work point in the center of mass. It works while the code is executed by a click event of a button I've added to my ribbon, which is fine for a simple feature like this.
For more complex add-ins I want the click event of a button on the ribbon to open a WPF window which contains its own set of buttons and controls which will execute my code.
Here is a code snippet that shows what happens when a MyButton (that's the button added to the ribbon) is clicked. This implementation works
Private Sub MyButton_OnExecute(Context As NameValueMap)
    Try
       Dim oPartDoc As PartDocument
       Dim oPartCompDef As PartComponentDefinition
       oPartDoc = _inventor.ActiveDocument
       oPartCompDef = oPartDoc.ComponentDefinition
       Dim oCenterOfMass As Point
       Dim oWorkPoint As WorkPoint
       oCenterOfMass = oPartCompDef.MassProperties.CenterOfMass
       oWorkPoint = oPartCompDef.WorkPoints.AddFixed(oCenterOfMass)
       Catch ex As Exception
       MsgBox("Center of mass property could not be found")
       End Try
End Sub
Now I've changed MyButton so that clicking it shows a WPF window called Window1:
     Dim window As New Window1
     window.Show()
 End Sub
That window contains just one button which should put a work point in the center of mass. The Window1 code looks like this:
Imports System.Runtime.InteropServices
Imports Inventor
Public Class Window1
    Private Sub Button_Click(sender As Object, e As RoutedEventArgs)
        Try
            Dim _inventor As Inventor.Application
        End Try
    End Sub
End Class
Now there is some bug on line 11. I can't get a reference to active document but I don't know how to fix it. I'm no developer and I already find add-in creation pretty arcane.
 I've created my add-in following a tutorial at: Jelte de Jong (hjalte.nl).
The entire visual studio project in its broken state is in the attachments ("CenterOfMass - project files.zip")
I've also added a compiled, working version that doesn't use a WPF window. It should appear in Part environment in 3d model tab in work features panel ("CenterOfMass - compiled and working.zip").
The project contains:
- a CenterOfMass
JelteDeJong
in your file Window1.xaml.vb I'm missing the constructor. I guess that you need to add this:
Private ReadOnly _inventor As Inventor.Application
Public Sub New(inventor As Inventor.Application)
    ' This call is required by the designer.
    InitializeComponent()
    _inventor = inventor
End Sub
That will break your button class. You have to change the sub "MyButton_OnExecute(Context As NameValueMap)" (in file MyButton.vb) to this:
    Dim window As New Window1(_inventor)
    window.ShowDialog()
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
piotrekdoro94
Thank you for help, your tutorials were very useful.
Unfortunately, I can't get CenterOfMass add-in to work. It keeps throwing in the same place. After suggested modifications MyButton.vb looks like this:
Imports Inventor
Public Class MyButton
    Private _inventor As Inventor.Application
    Private _settingsButton As ButtonDefinition
        SetupButtonDefinition()
        AddButtonDefinitionToRibbon()
    End Sub
    Private Sub SetupButtonDefinition()
        Dim conDefs As ControlDefinitions = _inventor.CommandManager.ControlDefinitions
        _settingsButton = conDefs.AddButtonDefinition(
            "Center of Mass",
            "Center of Mass",
            CommandTypesEnum.kEditMaskCmdType,
            Guid.NewGuid().ToString(),
            "Command creates a work point in the center of mass coordinates. Works in Part environment and is part of CenterOfMass add-in",
            "Create point in center of mass")
        AddHandler _settingsButton.OnExecute, AddressOf MyButton_OnExecute
    End Sub
    Private Sub AddButtonDefinitionToRibbon()
        Dim ribbon As Ribbon = _inventor.UserInterfaceManager.Ribbons.Item("Part")
        Dim ribbonTab As RibbonTab = ribbon.RibbonTabs.Item("id_TabModel")
        Dim ribbonPanel As RibbonPanel = ribbonTab.RibbonPanels.Item("id_PanelA_ModelWorkFeatures")
        ribbonPanel.CommandControls.AddButton(_settingsButton)
    End Sub
        window.ShowDialog()
    End Sub
End Class
And the Window1.xaml.vb looks like this:
Imports Inventor
    End Sub
        Try
        End Try
    End Sub
End Class
I don't think I understand what the code snippets you've provided do. As I understand it:
- in MyButton.vb
    Dim window As New Window1(_inventor) 'Here I'm passing a field of a MyButton instace to the Window1 constructor. _inventor=inventor means that _inventor is an Inventor application object
    window.ShowDialog() 'Here I'm switching from modal Show() to non-modal Showdialog(). I'm not sure if it means something
End Sub
 In Window1.xlam.vb:
Private ReadOnly _inventor As Inventor.Application 'I'm declaring a field _inventor which is an Inventor application object
Public Sub New(inventor As Inventor.Application) 'This is a constructor for Window one which is called from MyButton.vb
    InitializeComponent() 'I'm not sure why this is necessary. From quick googling it seems that Visual Studio adds this to a Sub New automatically
End Sub
piotrekdoro94
I've managed to cobble together something resembling a solution but it's pretty ugly and I would gladly use something else.
I've deleted my WPF window (Window1) from my project folder. Then I've rewritten the "CenterOfMass" as a separate winforms app and compiled it. The winform has a button with an onClick event that looks like this:
Imports Inventor
Imports System.Text.RegularExpressions
Imports System.Windows.Forms
Imports System.IO
Imports System.Xml.Serialization
Imports System.Security.Cryptography
Imports System.Diagnostics.Contracts
Public Class Form1
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim InventorApp As Inventor.Application
        InventorApp = Marshal.GetActiveObject("Inventor.Application")
        oPartDoc = InventorApp.ActiveDocument
        oPartDoc.Activate()
        Try
            MessageBox.Show("Connected To Inventor session")
            MessageBox.Show("Failed to connect to inventor session")
        End Try
        Try
        Catch
            MsgBox("No center of mass detected")
        End Try
    End Sub
End Class
Now I use the ribbon button to run a compiled version of the winforms app shown above. The ribbbon button executes the following code when clicked:
     Process.Start("C:\Users\Piotrekdoro\Desktop\InventorVBA\Center of mass 1\bin\Debug\WindowsApp1.exe")
 End Sub
There are two big downsides with this approach that might emerge as far as I can predict:
  • Problems with debugging - if there is a bug in the separate executable then debugger will not find it
  • Add-in as a process is lumped with the main Inventor process. When I use it to launch a separate executable I create a separate process, which means that the add-in can't directly talk with UI. It also means that the code in the separate program won't be able to use Inventor specific events. I don't need this functionality at the moment, but I think that both of these issues could be solved by handling events within the add-in and creating intermediary "input.txt" and "output.txt" files which would be used for the addin and UI to communicate with each other
