how do I get date form BOM using Ilogic
Darkforce_the_ilogic_guy
Sub main()
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews
bRows = oBOMView.BOMRows
Dim bRow As BOMRow
For Each bRow In bRows
'Enter code here
Next
End Sub
I am trying to build an code that read  data form BOM. I want to read
item , part number, qty, description, G_L (Custom), Raw material, Status (Custom)
and add to an Excel .
but can´t get the  for each  to run  .... I was trying to rewrite an VBA code I found  on the net .. that I beleive would do almost what I want ..( see sample below)... any I did why it fail ... you are welcome to help with the rest of the code
'Public Sub Main()
'Dim oDoc As AssemblyDocument
'Set oDoc = ThisApplication.ActiveDocument
'Dim oBOM As BOM
'Set oBOM = oDoc.ComponentDefinition.BOM
'oBOM.PartsOnlyViewEnabled = True
'Dim oBOMView As BOMView
'Set oBOMView = oBOM.BOMViews.Item("Parts Only")
'Call ExportToExcel(oBOMView.BOMRows)
'End Sub
'Public Function ExportToExcel(bRows As BOMRowsEnumerator)
'Dim xlApp As Excel.Application
'Set xlApp = GetObject("", "Excel.Application.15")
'Dim xlWorkbook As Workbook
'Set xlWorkbook = xlApp.Workbooks.Open("C:\SolidCAD\Inventor Training Files\iLOGIC\Beam\Beam Assembly - BOM.xls")
'Dim xlWorksheet As WorkSheet
'Set xlWorksheet = xlWorkbook.Worksheets.Item("TEST")
'Dim row As Integer
'row = 5
'xlWorksheet.Range("B4").Value = "ITEM"
'xlWorksheet.Range("C4").Value = "QTY"
'xlWorksheet.Range("D4").Value = "DESC"
'xlWorksheet.Range("E4").Value = "Part Number"
'Dim bRow As BOMRow
'For Each bRow In bRows
'Dim rDoc As Document
'Set rDoc = bRow.ComponentDefinitions.Item(1).Document
'Dim docPropertySet As PropertySet
'Set docPropertySet = rDoc.PropertySets.Item("Design Tracking Properties")
'xlWorksheet.Range("B" & row).Value = bRow.ItemNumber
'xlWorksheet.Range("C" & row).Value = bRow.ItemQuantity
'xlWorksheet.Range("D" & row).Value = docPropertySet.Item("Description").Value
'xlWorksheet.Range("E" & row).Value = docPropertySet.Item("Part Number").Value
'row = row + 1
'Next
'xlWorkbook.Save
'xlWorkbook.Close (False)
'xlApp.Quit
'End Function
dutt.thakar
@Darkforce_the_ilogic_guy
Can you try this code and see if it works in iLogic? Please change your excel file and excel sheet if needed, I had copied the same from the code you provided.
Public Sub Main()
Dim oBOM As BOM
End Sub
ExcelFile ="C:\SolidCAD\Inventor Training Files\iLOGIC\Beam\Beam Assembly - BOM.xlsx"
ExcelSheet = "TEST"
Dim row As Integer
row = 5
GoExcel.CellValue(ExcelFile,ExcelSheet,"B4") = "Item"
GoExcel.CellValue(ExcelFile,ExcelSheet,"C4") = "QTY"
GoExcel.CellValue(ExcelFile,ExcelSheet,"D4") = "DESCR"
GoExcel.CellValue(ExcelFile,ExcelSheet,"E4") = "Material"
Dim bRow As BOMRow
GoExcel.CellValue(ExcelFile,ExcelSheet,"B" & row) = bRow.ItemNumber
GoExcel.CellValue(ExcelFile,ExcelSheet,"C" & row) = bRow.ItemQuantity
GoExcel.CellValue(ExcelFile,ExcelSheet,"D" & row) = docPropertySet.Item("Description").Value
GoExcel.CellValue(ExcelFile,ExcelSheet,"E" & row) = docPropertySet.Item("Part Number").Value
row = row + 1
Next
GoExcel.Save
GoExcel.Close
GoExcel.ClearCache
End Function
Hope this will be helpful.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Do you know how to make it all Levels with ?  and with an Delimiter.. I need the same output as if I save an Excel... but I want på write down in an templete files(Excel file)... and with the properties I name ealyer
dutt.thakar
Try this. You can edit the properties that you want to copy and add more in the BOLD part in code.
Class BOMEXport
	Shared row As Integer = 5
Public Sub Main()
Dim oBOM As BOM
oBOM.StructuredViewEnabled = True
oBOM.StructuredViewFirstLevelOnly = False
oBOM.StructuredViewDelimiter = "."
oBOMView = oBOM.BOMViews.Item("Structured")
End Sub
ExcelSheet = "TEST"
GoExcel.CellValue(ExcelFile,ExcelSheet,"D4") = "DESC"
GoExcel.CellValue(ExcelFile,ExcelSheet,"E4") = "Part Number"
GoExcel.CellValue(ExcelFile,ExcelSheet,"F4") = "G_L (Custom)" 'add more line below as per your property requirement Dim bRow As BOMRow For Each bRow In bRows Dim rDoc As Document rDoc = bRow.ComponentDefinitions.Item(1).Document Dim docPropertySet As PropertySet docPropertySet = rDoc.PropertySets.Item("Design Tracking Properties") GoExcel.CellValue(ExcelFile,ExcelSheet,"B" & row) = bRow.ItemNumber GoExcel.CellValue(ExcelFile,ExcelSheet,"C" & row) = bRow.ItemQuantity GoExcel.CellValue(ExcelFile,ExcelSheet,"D" & row) = docPropertySet.Item("Description").Value GoExcel.CellValue(ExcelFile,ExcelSheet,"E" & row) = docPropertySet.Item("Part Number").Value 'add more line below as per your property requirement row = row + 1 If Not bRow.ChildRows Is Nothing Call ExportToExcel(bRow.ChildRows) End If Next GoExcel.Save GoExcel.Close GoExcel.ClearCache End Function End Class
Dutt Thakar
LinkedIn
Do you know how to get my custom properties ? call G_L ?
dutt.thakar
To get custom properties, you need to change the property set. To get all your custom Properties value, you need to reference them with "User defined Properties" in property set. I have added these extra lines to the above code for getting G_L. Replace the below code in Public Function.
ExcelSheet = "TEST"
GoExcel.CellValue(ExcelFile,ExcelSheet,"F4") = "G_L" 'add more line below as per your property requirement
Dim bRow As BOMRow
Dim docPropertySet1 As PropertySet
docPropertySet1 = rDoc.PropertySets.Item("User Defined Properties")
'You can add below all your custom properties, they must be referenced with docPropertySet1
GoExcel.CellValue(ExcelFile, ExcelSheet, "F" & row) = docPropertySet1.Item("G_L").Value row = row + 1 If Not bRow.ChildRows Is Nothing Call ExportToExcel(bRow.ChildRows) End If Next GoExcel.Save GoExcel.Close GoExcel.ClearCache End Function
Dutt Thakar
LinkedIn
