How do I create this FRP/Glassfiber Composites as a material?
Darkforce_the_ilogic_guy
Advisor Advisor
how do I create a material like this one. that dont have the same strength in x , y, z? hope you can help with add the right material spec.   should I just copy an inventor wood material.  or how does i do this?
Michael.Navara
In material editor (tested in 2025) you can set Physical->Behavior to Orthotropic and you can define different values for different directions.
