How do I check if a parameter exists?
harvey_craig2RCUH
harvey_craig2RCUH
As goes the title, I have tried to mimic the shared version:
SharedVariable.Exists("VariableName")
 by doing this:
If Parameter.Exists(Connection, "Hex_AFc") Then
	MsgBox("this parameter exists")
Else
	MsgBox("this parameter does not exist")
End If
but that doesn't work. The best I've managed is a try catch:
Try
	If Parameter(Connection, "Hex_AFc")
	End If
Catch
End Try
but it's not very slick. Is there a better way?
Harvey
Replies (10)
JelteDeJong
If you are willing to use the Inventor API (in an Ilogic rule) then you could try something like this:
Dim doc As PartDocument = ThisApplication.ActiveDocument
Dim def As PartComponentDefinition = doc.ComponentDefinition
Dim parameters = def.Parameters.Cast(Of Parameter)
Dim exsits = parameters.Any(Function(p) p.Name.Equals("test1"))
If exsits Then
	MsgBox("Parameter exist")
End If
Jelte de Jong
Blog: hjalte.nl - github.com
ngnam1988
Hi @JelteDeJong
I got an error message:
Could you please help me? Thanks!
JelteDeJong
I’m on holiday and don’t have a computer here. But just 2 quick points. Are you running inventor 2025? It has some late binding issues.
this code (as it is) only works on part.
Jelte de Jong
AndrewHumiston
good monring,
here is the code i use to check if a parameter exists, it uses a loop to check a name. i've found it works well and is robust.
'set ref to active doc
Dim oActiveDoc As Document = ThisApplication.ActiveDocument
'set ref to user parameters
Dim oUserParams As UserParameters = oActiveDoc.ComponentDefinition.Parameters.UserParameters
Dim oUserParam As UserParameter
'set ref to counter
Dim i As Integer
i = 1
'set up param search name
Dim oParamSearchName As String = "TestName"
For Each oUserParam In oUserParams
	If oUserParam.Name = oParamSearchName Then
		Call MsgBox("User Paramater - " & oParamSearchName & " - Exist.", vbOKOnly, "Check User Paramaters")
		Exit For
	End If
	'if count = i then param doesn't exisit trip message box
	If i = oUserParams.Count Then Call MsgBox("User Paramater - " & oParamSearchName & " - Does NOT Exist.", vbOKOnly, "Check User Paramaters")
	i = i + 1
Next
ryan.rittenhouse
Function ParameterExists(paramName As String) As Boolean
	Dim doc As Document = ThisDoc.Document
	Dim params As Parameters
	If doc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
		params = doc.Parameters
	Else
		params = doc.ComponentDefinition.Parameters
	End If
	For Each p As Parameter In params
		If p.Name = paramName Then Return True
	Next p
	Return False
End Function 'ParameterExists
You can add this function to your code - it'll return True if the parameter name you give it exists in the document.
Curtis_Waguespack
@ngnam1988
I typically just use a try/catch to try and set the value, and then catch the error when it does not exist and add it.
Keep in mind that drawings and models have the user parameter set organized a bit differently, since drawings do not contain a component definition.
If Thisapplication.ActiveDocument.DocumentType = DocumentTypeenum.kDrawingDocumentObject Then
	oUserParams = ThisDoc.Document.Parameters.UserParameters
Else
	oUserParams = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters
End If
dValue = 99
Try
	Parameter( "Foo") = dValue
Catch
	oParam = oUserParams.AddByValue("Foo", dValue, UnitsTypeEnum.kDefaultDisplayLengthUnits)
End Try
If you are working with assembly occurrences, then something like this will work
Dim oOcc As ComponentOccurrence = Component.InventorComponent("MyPart")
oUserParams = oOcc.Definition.Document.ComponentDefinition.Parameters.UserParameters
dValue = 99
Try
	Parameter(oOcc.Name, "Foo") = dValue
Catch
End Try
_dscholtes_
@harvey_craig2RCUH wrote:
Try
	End If
Catch
End Try
You can make this look a little better by using a single line IF-statement. You don't need an IF...End If-construction when there's not a block of code in/between it. #Just a suggestion.
Personally, I use a dedicated sub procedure similar to @ryan.rittenhouse
ngnam1988
Thanks @Curtis_Waguespack
I'm trying another way like @AndrewHumiston and @ryan.rittenhouse because I'm using "On Error Resume Next" Syntax.
Thanks all of you!
ngnam1988
Hi @JelteDeJong
I'm working on Inventor 2023. I'm trying find some new way to check existed parameters. I'm very curious about your codes. It was really different from my previous understanding.
AndrewHumiston
good morning,
I want to caution you on using 'on error' handling.
In my experience it is better to solve the issue that is causing the error than to resume when an error has happened.
i will share why. the company i work for has a configurable sales CAD system that populates a model with other assemblies that are controlled by turning off/on visibility. I know terrible idea, but its been around for about 10 years, all the code is located in one rule that is approx. 1000 lines long, and uses 'on error; & "goto" syntax. While it seems like a good practice to get the job done, in reality it is 'lazy' coding. When you are the person coming behind code, it is tough to follow those kinds of event handlers. Its taken way to many hours to find the simplest bugs to flush out how it works and why.
i hope this helps, please reach out with any questions, I don't pretend to know everything, but I will sure try to answer your question!
@AndrewHumiston - this post has been edited due to Community Rules & Etiquette violation.
