- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I created iLogic below.
However, I do not want to display the "Length" value among the iProperties values.
How can I change iLogic?
Sub main Dim oDoc As PartDocument = ThisDoc.Document Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition Dim LengthTotal As Double = 0 Dim oPath As Path For Each oSweep As SweepFeature In oDef.Features.SweepFeatures oPath = oSweep.Definition.Path LengthTotal = LengthTotal + GetLengthOfSweep(oPath) Next Dim oUParams As UserParameters = oDoc.ComponentDefinition.Parameters.UserParameters Dim oExists As Boolean = False Dim oParamName As String = "Length" For Each oUParam As UserParameter In oUParams If oUParam.Name = oParamName Then oUParam.Value = LengthTotal oExists = True End If Next If oExists = False Then oUParams.AddByValue(oParamName, LengthTotal, UnitsTypeEnum.kDefaultDisplayLengthUnits) End If ParaExport(oDef.Parameters.UserParameters, oParamName, kZeroDecimalPlacePrecision) oDoc.Update iProperties.Value("custom", "SIZE1") = "t" & Parameter("T0") & "x(" & Round(Parameter("Length"), 1) & ")x" & Round(Parameter("V0"), 1) End Sub Private Function GetLengthOfSweep(ByVal oPath As Path) As Double Dim TotalLength As Double = 0 Dim oCurve As Object Dim oCurveEval As CurveEvaluator Dim MinParam As Double Dim MaxParam As Double Dim length As Double For i As Integer = 1 To oPath.Count oCurve = oPath.Item(i).Curve oCurveEval = oCurve.Evaluator oCurveEval.GetParamExtents(MinParam, MaxParam) oCurveEval.GetLengthAtParam(MinParam, MaxParam, length) TotalLength = TotalLength + length Next Return TotalLength End Function Private Sub ParaExport(ByRef oUParas As UserParameters, ByVal oParaName As String, _ ByVal oDecimalPrecision As CustomPropertyPrecisionEnum) For Each oUPara As UserParameter In oUParas If oUPara.Name = oParaName Then oUPara.ExposedAsProperty = True Dim oCPF As CustomPropertyFormat = oUPara.CustomPropertyFormat oCPF.PropertyType = CustomPropertyTypeEnum.kNumberPropertyType oCPF.Precision = oDecimalPrecision oUPara.Comment = "스윕길이로 산출함." Exit Sub End If Next End Sub
