Announcements
How do delete the Angle Constraint of Selected Components in Assembly ILogic
I want to delete the Angle Constraint of Components which are selecting by me.
I have tried below Loop code but it showing attached error. Can you please help me to find the error in this code.
Dim oAsm As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition = oAsm.ComponentDefinition
Line1 :
comp = ThisApplication.CommandManager.Pick(
SelectionFilterEnum.kAssemblyOccurrenceFilter,
"Select a components")
AngleConstraint.Delete(comp)
GoTo Line1
Thanks & Regards,
Manoj Sampath
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below iLogic code
Line1 :
Dim oConstraint As AssemblyConstraint
For Each oConstraint In comp.Constraints
    If oConstraint.Type = kAngleConstraintObject Then
         Call oConstraint.Delete()
Next
GoTo Line1
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
@chandra.shekar.g
Hi Sir,
I have done some update the Loop Code. Now I'm using below code and it is working fine.
oAsm = ThisApplication.ActiveDocument
oAsmCompDef = oAsm.ComponentDefinition
Line1 :
Dim oComp As ComponentOccurrence
oComp = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select a components")
If oComp Is Nothing Then
Exit Sub
Dim oCons As AssemblyConstraint
For Each oCons In oComp.Constraints
If oCons.Type = Inventor.ObjectTypeEnum.kAngleConstraintObject Or oCons.Type = Inventor.ObjectTypeEnum.kAngleConstraintProxyObject Then
oCons.Delete
Next
GoTo Line1
Thanks & Regards,
Manoj Sampath
