Hi @johnPGNFG
Here is an iLogic example, based on the "Is cylindrical face interior or exterior?" API Help files Sample
I hope this helps.
Curtis
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oHLSet As HighlightSet
oHLSet = oDoc.CreateHighlightSet
Dim oRed As Color
oRed = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
oRed.Opacity = 0.1
oHLSet.Color = oRed
Dim oHLSet2 As HighlightSet
oHLSet2 = oDoc.CreateHighlightSet
Dim oGreen As Color
oGreen = ThisApplication.TransientObjects.CreateColor(0, 255, 0)
oHLSet2.Color = oGreen
For Each oSolid In oDoc.ComponentDefinition.SurfaceBodies
Dim oFace As Face
For Each oFace In oSolid.Faces
If Not oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then Continue For
If oFace.Edges.Count = 2 Then Continue For 'skip holes or full circle cuts
Dim oCylinder As Cylinder
oCylinder = oFace.Geometry
Dim params(1) As Double
params(0) = 0.5
params(1) = 0.5
' Get point on surface at param .5,.5
Dim points(2) As Double
Call oFace.Evaluator.GetPointAtParam(params, points)
' Create point object
Dim oPoint As Point
oPoint = ThisApplication.TransientGeometry.CreatePoint _
(points(0), points(1), points(2))
' Get normal at this point
Dim normals(2) As Double
Call oFace.Evaluator.GetNormal(params, normals)
' Create normal vector object
Dim oNormal As Vector
oNormal = ThisApplication.TransientGeometry.CreateVector _
(normals(0), normals(1), normals(2))
' Scale vector by radius of the cylinder
oNormal.ScaleBy(oCylinder.Radius)
' Find the sampler point on the normal by adding the
' scaled normal vector to the point at .5,.5 param.
Dim oSamplePoint As Point
oSamplePoint = oPoint
oSamplePoint.TranslateBy(oNormal)
' Check if the sample point lies on the cylinder axis.
' If it does, we have a hollow face.
' Create a line describing the cylinder axis
Dim oAxisLine As Line
oAxisLine = ThisApplication.TransientGeometry.CreateLine _
(oCylinder.BasePoint, oCylinder.AxisVector.AsVector)
'Create a line parallel to the axis passing thru the sample point.
Dim oSampleLine As Line
oSampleLine = ThisApplication.TransientGeometry.CreateLine _
(oSamplePoint, oCylinder.AxisVector.AsVector)
If oSampleLine.IsColinearTo(oAxisLine) Then
oHLSet.AddItem(oFace)
MsgBox("Interior face.", , "iLogic")
Else
oHLSet2.AddItem(oFace)
MsgBox("Exterior face.", , "iLogic")
End If
Next
Next
