& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
How can I assign the cross-section plan direction to the right and left as I want?
Hi @nebi_guler
Assuming you have allready create the view then you can use reversedirection help page here.
Syntax
SectionDrawingView.ReverseDirection()
Not tested but it should look like this I believe.
Dim sectionView As SectionDrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select View")
sectionView.ReverseDirection
Hi @A.Acheson I knew this answer and the halo I was looking for was right in front of my eyes and I couldn't see it. Thank you.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
