How can I automate Save/Create button of Teamcenter Tab of Autodesk Inventor using programming?
kawsar.cuetcse
kawsar.cuetcse
I am developing an automation tool to synchronize datasets between Inventor and Teamcenter. To complete the tool I need to automate Save/Create button. How can I automate this button using programming language?
Fadi.Hanna.MO
Please could you share how you proceeded here?
I facing same issue, and it seams to be the case that it is not possible as TCAI doesn't have an API?
kawsar.cuetcse
I did not find any API. I have used UI automation to do save functionality. But its performance is not so much good.
Fadi.Hanna.MO
Thanks for reply!
Ok, to bad. I'll look in to it to see if there is a good RPA that can do it smoothly.
All the best,
Fadi
linjone09
Hi,  u are in the ATMO?
