Holes counting and reflecting the results to a drawing
Ahmed.shawkyXTZHN
Ahmed.shawkyXTZHN
Hi all , I have the below code from Jhoel special thanks to  him , but I have two things pending ,
1- this code is counting holes and punches for assembly with part level , I wanted to be assembly with subassembly level then parts ,
2 - get the result's in table in the drawing.
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oHoles As New List(Of String)
Dim oPunches As New List(Of String)
Dim UoM As UnitsOfMeasure = oAsm.UnitsOfMeasure
For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences
	If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject AndAlso oOcc.Definition.Document.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		Dim oDoc As PartDocument = oOcc.Definition.Document
		Dim oCD As SheetMetalComponentDefinition = oDoc.ComponentDefinition
		If oCD.HasFlatPattern = False Then
			oCD.Unfold
			oCD.FlatPattern.ExitEdit
			oDoc.Close
			oAsm.Activate
		'Add all holes (diameters) to a list
		Dim oFace As Face = oCD.FlatPattern.TopFace
		For Each oLoop As EdgeLoop In oFace.EdgeLoops
			'Make sure the edgeloop is a circle
			If oLoop.IsOuterEdgeLoop = False AndAlso oLoop.Edges.Count = 1 _
				AndAlso oLoop.Edges(1).GeometryType = CurveTypeEnum.kCircleCurve
				oHoles.Add(UoM.GetStringFromValue(oLoop.Edges(1).Geometry.Radius * 2, UoM.LengthUnits))
		Next
		For Each oPunch As PunchToolFeature In oCD.Features.PunchToolFeatures
			For i = 1 To oPunch.PunchCenterPoints.Count
				oPunches.Add(System.IO.Path.GetFileNameWithoutExtension(oPunch.iFeatureTemplateDescriptor.LastKnownSourceFileName))
			Next
		Next
Next
For Each oProp As Inventor.Property In oAsm.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
	If oProp.Name.StartsWith("Hole: ") Or oProp.Name.StartsWith("Punch: ") Then oProp.Delete
Next
'Sort the list
oHoles.Sort(Function(a, b) UoM.GetValueFromExpression(a, UoM.LengthUnits).CompareTo(UoM.GetValueFromExpression(b, UoM.LengthUnits)))
'Step through the list and create properties of diameter and count.
Dim currCount As Integer = 0
For i = 0 To oHoles.Count - 1
	If i > 0 AndAlso oHoles(i) <> oHoles(i - 1)
		iProperties.Value("Custom", "Hole: " & oHoles(i - 1)) = currCount
		MsgBox(oHoles(i - 1) & vbCrLf & "Count = " & currCount)
		currCount = 1
	Else
		currCount += 1
	If i = oHoles.Count - 1
		MsgBox(oHoles(i) & vbCrLf & "Count = " & currCount)
		iProperties.Value("Custom", "Hole: " & oHoles(i)) = currCount
Next
oPunches.Sort(Function(a, b) a.CompareTo(b))
currCount = 0
For i = 0 To oPunches.Count - 1
	If i > 0 AndAlso oPunches(i) <> oPunches(i - 1)
		iProperties.Value("Custom", "Punch: " & oPunches(i - 1)) = currCount
		MsgBox(oPunches(i - 1) & vbCrLf & "Count = " & currCount)
		currCount = 1
	Else
		currCount += 1
	If i = oPunches.Count - 1
		MsgBox(oPunches(i) & vbCrLf & "Count = " & currCount)
		iProperties.Value("Custom", "Punch: " & oPunches(i)) = currCount
Next
oAsm.Update
Thanks.
JhoelForshav
Hi @Ahmed.shawkyXTZHN
You can use AllReferencedDocuments to dig through the subassemblies as well:
For Each oDoc As Document In oAsm.AllReferencedDocuments
	If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject AndAlso TypeOf (oDoc.ComponentDefinition) Is SheetMetalComponentDefinition
		If oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc).Count > 0
			Dim occCount As Integer = oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc).Count
				oCD.Unfold
				oDoc.Close
				oAsm.Activate
					For j = 1 To occCount
					Next
			Next
				Next
				Next
			Next
Next
Next
		currCount = 1
	Else
		currCount += 1
Next
currCount = 0
		currCount = 1
	Else
		currCount += 1
Next
oAsm.Update
Ahmed.shawkyXTZHN
@JhoelForshav  i tried the above code it gives me the below error
"Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))"
JhoelForshav
Maybe you have some bad sheet metal parts in your assembly that can't be unfolded?
Try this:
			Try
				oCD.Unfold
				oDoc.Close
				oAsm.Activate
			Catch
			MsgBox("cannot unfold " & oDoc.DisplayName)
			oDoc.Close
			Continue For
			End Try
					Next
			Next
				Next
				Next
			Next
Next
Next
		currCount = 1
	Else
		currCount += 1
Next
currCount = 0
		currCount = 1
	Else
		currCount += 1
Next
oAsm.Update
Ahmed.shawkyXTZHN
@JhoelForshav  hello Jhoel , I have extra challenge  😊, can we get the result of the punch by punch ID not punch name
as i have one punch name but under this punch there is 10 punch ID with different hole sizes and properties , thanks.
JhoelForshav
I don't have any punches myself with different ID to try on so I haven't tried this code but it should work. If the punch doesn't have an ID it uses the name, otherwise it uses the ID.
			Try
					oCD.Unfold
					oDoc.Close
					oAsm.Activate
			Catch
				oDoc.Close
				Continue For
			End Try
					Next
			Next
				Dim PunchID As String = oPunch.iFeatureDefinition.PunchId
						If PunchID <> ""
							oPunches.Add(PunchID)
						Else
					Next
				Next
			Next
Next
Next
		currCount = 1
	Else
		currCount += 1
Next
currCount = 0
		currCount = 1
	Else
		currCount += 1
Next
oAsm.Update
An Idea could be to use a combination of name and ID instead, but as it is now it's only using the ID if it exists.
Ahmed.shawkyXTZHN
Hi @JhoelForshav , regarding the above code for counting holes and punches , can we link it to custom property so we can get the punch and hole part wise in the cutting list , thanks.
