Announcements
Hole Feature not changing as per iLogic rules
bhavik4244
bhavik4244
I am getting a weired problem with changing of Hole size to M17x2 to M22x3.
Here in Flange, I have given mounting hole with treading and I want to change as per different size, Hence I was given case rules in iLogic but when I switched cases it shows an error for threading/Hole features. I have attached snap of errors.
Awaiting for kind answer.
Bhavik Suthar
Bhavik Suthar
Darkforce_the_ilogic_guy
may I see the ilogic rules that you are using ?
bhavik4244
Please find in attached file.
Bhavik Suthar
Sergio.D.Suárez
Can you attach file here?
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
this is a very big code... the first thing that i See is that there are no M22x3  in the code... only M22x2 and this is comment out... and no M17x anything... is this not simple of error that it does not know what to do if you have not type an cash for the change that fail ?
