Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Hide curve in drawing view by iLogic
6 REPLIES 6
artemijs.nille
584 Views, 6 Replies
I have created an entity "AnsaugDKanteDSAussen " in 3d model of a part.
Dim Blatt_1 = ThisDrawing.Sheets.ItemByName("Blatt:1")
Dim ANSICHT23 = Blatt_1.DrawingViews.ItemByName("ANSICHT23")
Dim AnsaugDKanteDSAussen = ANSICHT23.GetIntent("AnsaugDKanteDSAussen")
In the picture below you can see this curve in the drawing view.
How can i hide this curve by iLogic?
6 REPLIES 6
Once you found the curve (segment) you can set its visibility. You need to do this on the 'drawingCurveSegment' and not the 'DrawingCurve'
Dim activeSheet As Sheet
activeSheet = ThisApplication.ActiveDocument.activeSheet
Dim crv As DrawingCurveSegment
crv = ThisApplication.CommandManager.Pick(kDrawingCurveSegmentFilter, "pick curve")
crv.Visible = False
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Property Editor | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle
Thank you for a reply.
In your solution i have to pick the curve, that i want to hide, MANUALLY.
How can i do it without manual picking, but by assigning my entity  "AnsaugDKanteDSAussen" to this "DrawingCurveSegment"?
I know, this was just an example. You need to retrieve the drawing curve from that intent, and then hide the segments that compose this curve.
I am sorry but i dont understand how should i do that.
My Intent is:
Dim AnsaugDKanteDSAussen = Deckscheibe.GetIntent("AnsaugDKanteDSAussen")
 how can i retrieve the curve from the Intent "AnsaugDKanteDSAussen"?
Ralf_Krieg
in reply to: artemijs.nille
Hello
Dim oDrawCurve As DrawingCurve = TryCast(AnsaugDKanteDSAussen.Geometry, DrawingCurve)
If oDrawCurve IsNot Nothing Then
	Dim oDrawCurveSegment As DrawingCurveSegment
	For Each oDrawCurveSegment In oDrawCurve.Segments
		oDrawCurveSegment.Visible = False
	Next
End If
R. Krieg
RKW Solutions GmbH
www.rkw-solutions.com
artemijs.nille
in reply to: Ralf_Krieg
Hello krieg,
thank you very much again.
it works perfeckt
